SLP Y pipe question, can anyone help?
Old Feb 4, 2002 | 09:39 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Alright, I don't think I have the money for full exhaust now, but I'm gonna price how much to install headers tomorrow. Worst case scenario, I can't afford the headers and install, I'm probably going to just get an SLP Y pipe. My question is, what size pipe does the SLP Y pipe come out to? Is it 3 inch? And they have 2, one is # 31030 for 83-91 V8 and the other is # 31031 for 82-92 V8. Is there some sort of difference? I'm probably going to get a new catback to go with the Y pipe, the flowmaster sounds pretty good, but it isn't quite what I hoped for. Thanks.
BTW, it's going on an '87 Z28 LB9 (305 TPI).
Old Feb 4, 2002 | 10:17 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
You're going to need the 31030 because SLP sent me the 31030 for my 91 RS Lo3 but the passenger side exhaust pipe on the Y-pipe was about an inch too short to reach my exhaust manifold. I told the guy I had an Lo3 engine but he insisted that 31030 was the right part number. I called them back and another guy said they should've shipped me part number 31031. After I got it I trial fitted it and found that the distance between the two pipes on the y-pipe were about 3/4" too wide. I took the y-pipe to a muffler shop and they cut the pipe near where the pipe crosses in front of the oil pan and made a slip joint so I could slip the two pipes together and have everything line up. I then tack welded the slip joint and then took everything off so I could weld everything together for a final assembly. The two 2 1/2" exhaust pipes come together into a 3" collector. I also fitted a Random Technology high flow cat to the Y-Pipe. My car sounds and performs like it has headers.
Old Feb 5, 2002 | 06:50 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Are you saying that SLP makes a Y-pipe that will connect to the stock exhaust manifolds?
Old Feb 5, 2002 | 01:47 PM
GKK's Avatar
GKK
Yes they do, the part number is 31031 for a 91 RS Camaro with the Lo3 engine. Here's a shot of it taken under the car.
Old Feb 5, 2002 | 01:53 PM
GKK's Avatar
GKK
Here's another shot of the pipes through the passenger side wheel well going to the Random Tech Cat.
Old Feb 5, 2002 | 03:27 PM
Hg's Avatar
Hg
Car: '87 Z
GKK: How do you know the Y pipe your engine uses is the same one my LB9 uses?
Old Feb 5, 2002 | 03:52 PM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
y pipe
Hi guys listen this may me a dumb ? But what kind of y pipe are you talking about an will it work on my 92 rs with a 305 tbi 5 speed. part numbers would be a big help to. Thanks
Old Feb 5, 2002 | 04:44 PM
Hg's Avatar
Hg
Car: '87 Z
Check out my first post, it's got the part numebers, and go to www.slponline.com to find them. Their site seems to be down though...
Old Feb 5, 2002 | 10:48 PM
GKK's Avatar
GKK
It's not the same Y-Pipe. My engine is an Lo3 and yours is an LB9. The Difference is in the length of the passenger side exhaust pipe. I have the SLP catalog and it lists 31030 for LB9's and 31031 for LO3's.
Old Feb 5, 2002 | 11:49 PM
Hg's Avatar
Hg
Car: '87 Z
GKK: Thanks man, I need one of them catalogs =) Found a place here that the guy *says* they sell the SLP 1 5/8 headers uncoated for 299$!! I forgot to ask if they have AIR or not, but that is WAY cheaper than anyplace i've seen.
Old Feb 8, 2002 | 10:31 PM
Tony86TA's Avatar
I believe you will need the 31030 for the TPI motor, with the cat adapter. Had mine installed yesterday. Man, what a huge difference from that stock unit! It gave the AeroChamber muffler a much throatier sound and it is more responsive as well. Got about 1 1/2" clearance under the floor before it goes to the cat, and I had to bend my tranny lines up alittle, as to not rub on the pipe. Very nice clearance around oil pan. Glad I went with it.
87iroctheo
Dec 4, 2016 11:47 AM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
lt1z350
Aug 28, 2015 05:57 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
