SLP header owners: how are the spark plug changes???
Old Feb 11, 2002 | 08:14 PM
Twin Turbo 358's Avatar
for those of you that may have the 1 3/4" SLP headers without AIR pipes, how hard are the spark plug changes? can you do them from the top? i don't have any smog stuff or EGR, or A/C / heater box. just wondering if i can still change them relatively quickly like i can now (with the gale banks twin turbo setup).
Old Feb 11, 2002 | 08:28 PM
cobrakiller1989's Avatar
i do them all from the top. i also have the smog removed and i relocated the heater tubes that are on the passenger side
Old Feb 11, 2002 | 08:30 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
On my Z it is not too bad.I can do all of them from the top,I have basically the same set up as you,SLP 1.75",non air,no pollution and no A/C.The back two plugs on driver side can be a PITA but not too bad.
Old Feb 11, 2002 | 09:24 PM
where is the O2 location on these SLP's with the y-pipe? is there any way i can keep my dual O2's that i have now? i plan on getting the SLP headers & Y and then run into a single Borla XR1 muffler (or something similar)...
thanks for all the info!
Old Feb 11, 2002 | 10:09 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Tho O2 location is on the inside of the driver side collector(on the header itself),facing the motor.I imagine you could weld in a bung on the passenger side,but I have never really looked at it so I can't say for sure how you would go about it.Hope this helps some..
Old Feb 18, 2002 | 03:58 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
spark plug on v8/w headers
they are not to bad if you have the shorty plug made by accel the stock plugs leave the wire to close to the headers (trust me ive melted plenty of wires) they part number for the accel plugs is 8219(sb400)but the 350 may use the same plug so im told )i also upgraded to the accel extreme heat 9000 wires they are only 8mm but i havent melted them and they work pretty good with my Msd hei setup. i only have to get under the car to get on plug(you all know what one im talking about the #7 plug)
ac delco also makes them plugs check youre local dealer they just started showing up in the new gm performance
83 Z28 sb400 edelbrock 650 holley high rise dual plane intake crane cams 274dur 450lift msd6a 010 flat top pistons keith black
rods 700r4 3:42 rear 40 series flowmaster 3" pipes
15:36 @ 95 mph 3.1 60ft on street tires they dont hook but they sure can cook
friend dont let friends drive fords or rice Http://brokeassracing.cc
Old Feb 18, 2002 | 12:24 PM
mcconahay37's Avatar
15-20 minutes to change all 8 from the top with SLP 1 3/4" headers no AIR. Saturday I had to change the plugs on my friend's RS, and remembered how bad it sucked to do them with manifolds and all the emmisions crap in there.
Old May 4, 2003 | 10:56 PM
rodrigo diaz's Avatar
Car: 92 rs
Engine: 5.0
Transmission: 5 speeds
i have slp`s and what i did is grab a regular sprk plug socket pull the rubber out and cut about 1/2 an inch from the socket now it fits fine with regular plugs but you can`t use a ratchet u have to use a wrench for craftsman socket use a 19mm wrench
Old May 6, 2003 | 09:37 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
Yeah, my 1-3/4" SLPs even with AIR actually improved the job of changing plugs. Kind of a pleasant surprise, I'm not used to that.
Old May 7, 2003 | 06:50 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Vice,
You using shorty plugs or stock length plugs? I've heard that the regular plugs work fine with stock heads and 90* plug boots. I'm doing the install and since you kept the AIR I asked you.
Thanks..Ed
Old May 7, 2003 | 09:37 PM
LastViceRS's Avatar
Car: '91 RS
Ed,
I'm using the stock plugs with 90* boots, and I'd say I've got a minimum of 1/4" clearance, although I haven't really looked that close. The only one I remember having trouble with was the #6 boot, and that was just getting it to snap onto the plug. It's a little crowded with the dipstick tube there.
Old May 8, 2003 | 04:02 AM
ebmiller88's Avatar
Thanks again!
Ed
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
