Just ordered the Mufflex 4"
Old Mar 14, 2002 | 10:10 PM
LIL QIK's Avatar
Yeap, finally ordered the mufflex 4" exhaust with the 3" y-pipe that are made for the hooker long tubes. Anyone else use this setup that might be able to offer any suggestions? I'm planning on running the down tubes from the turbos to the 3" y-pipe. Hopefully everything will work out as planned.
Old Mar 14, 2002 | 11:23 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I wish my engine was so power full I needed at 4" mufflex, you luckly ba.....jk. I wish I could help ya here, but I don't even use up all the space in my 3" cat back. :hail:
Old Mar 15, 2002 | 10:07 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Love the motor, that's one sweet setup.
Anyways, I don't run the hooker long tube setup but I do have experience with the mufflex system. One thing to look for is you may need to cut the intermediate pipe that meets the one coming over the axle. The pipe might be too long and if you cut it down it will fit closer to the body. When I did mine the exhaust sat low to the ground. After cutting almost 2 inches off of the pipe, it sits closer and more snug than the original one did.
Another thing you might look into is getting new exhaust hangers. The stock ones in the stock locations will work, but it just doesn't sit right. I used custom hangers and mine sits snug up in the rear of the car. Just by looking at it you can't even tell there's 4 inches of sewer tube under there, just looks like I've got a flowmaster with no tail pipes that you can see.
Good luck and if you have any other questions, send me an email or just reply here and I'll help any way I can.
Old Mar 17, 2002 | 11:30 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
I run a Mufflex y-pipe........
to a 3" Dynomax Bullit Muffler for the street. I run just the y-pipe at the track. I had to modify the stock tranny cross member to get it to fit w/o rattling. Also, I had to dimple the Hooker LTs in some places to get them away from the body.
I like the sound and the performance of the LTs and the mufflex.............
Take a look..............
http://www.geocities.com/cfrios/Phil...l?996948051310
Old Mar 18, 2002 | 01:02 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i have asked this before, but never really got an answer, for the guys that have the 4 inch system, do you think its possible to just buy the y pipe and make the rest of the system with manderal bent pipe? theres only what, 3 turns? From pictures the look like 2 90's, and maybe a 45 or a 60? I maybe wrong. I am trying to decide on this, or true duals for my 406, but I would like to lower my car someday. Do the long tubes hang to low to lower a car? thanks for any help.
Old Mar 18, 2002 | 07:26 PM
LIL QIK's Avatar
I had thought about that but with all the trial and error stuff that I've done in the past and countless dollars and knuckle busting, I decided that this time I was just going to go with something that I know works. I played it lazy this time.
Old Mar 18, 2002 | 08:24 PM
LilJayV10's Avatar
Engine: 406 Roller
lil qik, i looked at your car pics, thats amazing, is the car running? if so, how does it drive and how fast is it? whoa:hail: :hail:
Old Mar 19, 2002 | 07:25 PM
LilJayV10's Avatar
Engine: 406 Roller
any other inputs, cause i'm all about saving money on this part of my project, i wish i could take the lazy way out, lol. thanks.
Old Mar 20, 2002 | 01:44 AM
LIL QIK's Avatar
Nope, the project isn't quite finished yet and I'm not real sure how much longer it will take. Everytime I think I'm going to get a good jump on one part of the project, something else needs the money............For instance, someone stole the hood off my 2002 SS a few nights ago and my ded. was 500.00 which put me to a screaching hault on my intercooler phase. Sometimes I wonder if I'll ever get to hear it run. My all out goal is 9.50's on my 315/35-17 Drag Radials. Once I'm there, I'm happy and will consider the project to be a success. I'm glad you like the pics. Peoples appreciation of the motor and car are one of the main things that keep me going on it.
Fireslash
Apr 11, 2016 06:43 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
Bigold4x4
Sep 28, 2015 05:21 PM
