Emission hoses on headers
Old Mar 22, 2002 | 08:45 PM
92RedBird's Avatar
Do I really need the emission hoses on the headers?
Old Mar 23, 2002 | 12:51 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Depends on your local emissions laws. If they don't have a visual or don't require them, you can get headers without them and it won't make a difference. they're only used to inject air into the exhaust manifolds during warmup to lower emissions.
Old Mar 23, 2002 | 11:32 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Do you think its possible to pass without them? We don't have a visual here in Illinois, but we do have emissions testing.
Old Mar 23, 2002 | 01:52 PM
Yeah you should be able to pass without them. They are only used when the car is cold (your car would never pass an e-check warming up anyway). When its warmed up, the air is diverted to the cat.
Old Mar 23, 2002 | 03:02 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Cool.. thanks. I was originally going to try Hooker headers, but then found out they weren't emissions legal so I switched to possibly getting the Edlebrock TES headers. But if I could pass with the Hookers, maybe I'll get them.
Old Mar 23, 2002 | 10:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Which Hookers? Mine are legal. The 2460's are available with the A.I.R. tubes and would then be legal (with a y-pipe you get made to hook them into the cat).
Old Mar 24, 2002 | 12:59 AM
Car: 1989 IROC-Z
Engine: 383 stroker
Actually, the 2460's were the ones I was looking at. My Jeg's doesn't say they're available with AIR. How much did yours cost and where'd you get them from? Also, did they fit good? Thanks.
Old Mar 24, 2002 | 07:54 PM
DozaChris89TA's Avatar
I'm not sure what the 2460's are but I have hooker headers in my car and there emission legal in all 50 states. Its part # HOK-2055 from summit. Hope this is some help.
Old Mar 24, 2002 | 10:02 PM
Car: 1989 IROC-Z
Engine: 383 stroker
How did those fit? I checked it out, they sound pretty nice.
Old Mar 25, 2002 | 11:41 AM
Once you get them in they fit good, the installation is a lot easier if you can lift your engine about three inches but it is possible to do it with out. I did it with out lifting the engine and it took somwhere between 6-8 hrs to remove and install the new headers. If you do go with the hookers I strongly recomend seeing if you can get them without the factory coating if not then at least get them sandblasted and put a coating on yourself. I put 2 coats of por-15 on and three monts later there is still no rust.
Old Mar 25, 2002 | 10:50 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Ok cool thanks a lot for the help.
Old Mar 27, 2002 | 12:51 AM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Is the POR-15 a high temp coating.
Old Mar 27, 2002 | 08:19 AM
Car: 1989 IROC-Z
Engine: 383 stroker
No, I don't think POR-15 is high temp, but I know they make POR-20 which I believe is a high temp coating.
Old Mar 27, 2002 | 09:06 AM
oops my bad it was the por-20
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
racereese
Oct 10, 2015 09:39 PM
89fast5oh
Sep 8, 2015 09:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
