dual sides
Old Apr 9, 2002 | 03:04 AM
trans_am_racing's Avatar
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
dual sides
has anyone ever came up with a concept of side pipes on any 3'rd gens?, i have made my own just want to see if anyone else has them or not:lala:
Old Apr 9, 2002 | 09:50 AM
GoFast91Z28's Avatar
Yes...
Back when I was 17 I used Supertrap mufflers that mounted at a 45* angle just in front of the rear wheel well. I connected this to Edelbrock TES headers w/ stainless flex pipe. I sounded like my exhaust was in stereo because the 2 pipes were so far apart. Power was good but probably not as good as if I had an X-pipe plumbed in. The negatives were : I melted a couple of 2x2 holes in the underside of the ground effects from too much heat and the Supertrapps got real ugly from road grime and very low ground clearance.
Not a bad setup if you want to be different.
Old Apr 9, 2002 | 12:58 PM
Car: 2000 firehawk
Engine: ls1
heres my 3 inch pipe on the drivers side all i need is to weld my bracket hanger up then im gtg .....
________________________
87 ta <junker when bought for 400 $>
350 block w/305 heads
and a lot more to come
Brinkkl2000
Aug 4, 2018 08:29 AM
onefreakz
May 14, 2018 12:15 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
wruiz
Aug 11, 2015 02:59 PM
