[MA] A lot of stuff needed
Old Jul 14, 2009 | 05:42 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I am looking for a bunch of random stuff for my 1983 Pontiac Trans Am:
1. Doeskin Tan color interior plastics for the trunk, T-Top Headliner, T-Top Sunvisors, carpet, doors, seat belts.
2. center console light
3. 82-84 Firebird Trans Am Fenders with air collector vent.
4. 82-84 hook style t-tops
5. fuel pump sending unit for crossfire fuel injection 305CI V8 S VIN code
6. 15 inch Bowling Ball Hub caps
7. 1982 Trans Am round shifter
Old Jul 20, 2009 | 08:26 PM
KITT1983's Avatar
Re: A lot of stuff needed
bump
Old Jul 25, 2009 | 01:05 PM
KITT1983's Avatar
bump
Old Jul 29, 2009 | 07:27 PM
KITT1983's Avatar
bump
Old Aug 10, 2009 | 06:27 PM
KITT1983's Avatar
8. 1982-1984 gauge cluster
9. Motor and tranny mounts
10. 1982-1984 305ci V8 mechanical fan shroud
Old Aug 11, 2009 | 08:57 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I have the hook-style T-tops. You said you wanted pictures, what specifically do you wish to see?
The plastic trim on them has seen better days, but the glass is nice, and the mechanisms function properly.
I also think I have the fan shroud, but 1 of the mounting points is broken.
And an 82 2.8 gauge cluster
Let me know, thanks.
Old Aug 12, 2009 | 05:18 AM
KITT1983's Avatar
i need photos of the latching mechanism, the t-tops themselves and any defects
I need a V8 gauge cluster and photos. let me see photos of the shroud
Old Oct 5, 2009 | 08:54 PM
KITT1983's Avatar
9. 1982-1984 305ci V8 mechanical fan shroud
Old Oct 5, 2009 | 09:30 PM
I didnt get an email notification, I will get you some pics tomorrow.
Old Oct 6, 2009 | 04:09 AM
KITT1983's Avatar
sure i am still intrested please send me some photos
Old Oct 6, 2009 | 11:29 AM
They're in overall good shape, no significant scrathes in the glass, no cracks, chips, etc. the latches function and work just as they should. I think the plastic trim on them can be replaced with the trim from pin-tops, so thats not a big deal, anyway, heres some pics.
Pics:
Heres the latch, you can also see the cracked plastic
Heres the other t-top, it has a little crack around one of the screws
Heres an overall shot
Old Oct 6, 2009 | 06:22 PM
KITT1983's Avatar
Pics:
can you fix the broken plastic area?
Old Oct 6, 2009 | 06:29 PM
87whiteiroc's Avatar
Car: 87 Camaro
Engine: 5.7 350 TPI
i have the center console light and the fuel pump for a 305 almost brand new ill check the receipt and i dont know what the sending unit looks like but im sure its there is you can tell me where it is. i live in seekonk mass
Old Oct 6, 2009 | 06:45 PM
KITT1983's Avatar
Do you have any pictures? is it for a crossfire? do you have the GM part number?
Old Oct 6, 2009 | 07:21 PM
Car: 87 Camaro
Engine: 5.7 350 TPI
no its for a tbi i think i check the receipt and there is no part number it just says fuel pump and the price and labor. f#$%ing $325. basically i have the fuel pump and dont know where the sending unit is. about the light is it the one that is inside the center console near the shifter and window switches
Old Oct 6, 2009 | 07:33 PM
KITT1983's Avatar
do you have any pictures though?
Old Oct 6, 2009 | 07:39 PM
Car: 87 Camaro
Engine: 5.7 350 TPI
what do you want pictures of. the fuel pump is silver and located under the drivers side rear seat next to the brake lines.
Old Oct 6, 2009 | 08:28 PM
KITT1983's Avatar
the center console light or the fuel sending unit
Old Oct 22, 2009 | 07:50 PM
KITT1983's Avatar
Pics:
how much for it?
Old Oct 25, 2009 | 08:18 AM
KITT1983's Avatar
7. 1982-1984 305ci V8 mechanical fan shroud
Old Nov 4, 2009 | 03:42 PM
KITT1983's Avatar
9. Crossfire Incjection parts
10. cruise control unit
Old Nov 10, 2009 | 08:08 PM
KITT1983's Avatar
bump
Old Nov 12, 2009 | 05:40 PM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Chris call me dude i got in 3-82 t/a parts cars one has t-tops
7734904220
Dave
Old Dec 17, 2009 | 08:08 AM
KITT1983's Avatar
1. Doeskin Tan color interior plastics, T-Top Headliner, T-Top Sunvisors, carpet, doors, and seat belts.
2. 1982-1984 Firebird Trans Am Fender air extractor vents. I need both side vents
3. 1982-1983 hook style t-tops
4. 15 inch Bowling Ball Hub caps
5. 1982-1984 gauge cluster
6. Crossfire Injection parts: computer, intake, TBI's, throttle linkages
7. 1982-1984 cruise control set up
Old Dec 17, 2009 | 08:13 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I ahve a set of hook style t tops
Old Dec 17, 2009 | 09:01 PM
KITT1983's Avatar
do you have any pictures?
Old Dec 17, 2009 | 09:08 PM
kurfbird's Avatar
pm me your email and i will zsend you some pic this weekend
Old Feb 5, 2010 | 09:03 AM
KITT1983's Avatar
8. 1982-1992 f-body UMI Subframe connectors
9. 1982-1992 F-body louvers
Old Feb 10, 2010 | 02:40 PM
KITT1983's Avatar
bump
Old Nov 6, 2010 | 05:33 AM
KITT1983's Avatar
2. American Racing ARE 398 center caps
3. 1982-1992 F-body louvers
4. 1982-1984 center console parts
5. 1982-1984 rear seats solid back style and seat bottoms
6. 1982-1984 CFI cruise control linkage
Old Nov 13, 2010 | 10:29 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
kitt, did you see my 84 part out thread on necf? check it out, let me know if you can use anything.
Old Feb 20, 2012 | 06:01 AM
KITT1983's Avatar
bump
Old Feb 28, 2012 | 11:25 AM
freddy_2_Smooth's Avatar
Car: 87 formula
Engine: 350tpi
Axle/Gears: stock posi
I have a complete tan interior plastics. PM me with everything you need and I will give you price and pics.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
NBrehm
Aug 5, 2015 07:57 PM
