84 - 86 wiper motor cover w/pulse
Hello,
I'm looking for a replacement wiper motor cover, the kind with the built-in washer motor and pulse wipers:
http://www.austinthirdgen.org/parts/...ages/10-09.gif
P/N 22039684
Preferably with the torx screws included!
Postage would be to the UK...
Many thanks,
Neil
P/N 22039684
Many thanks,
Neil
Car: 92 Camaro RS
Engine: 355 L98 Carb
Transmission: WC T5
Axle/Gears: 3.73 Auburn Posi
Re: 84 - 86 wiper motor cover w/pulse
Here are the pictures that I have of the parts. I sent you a PM as well. I took a picture of the actual motor and the connector so you could compare it and make sure it was the right one for you.
That cover does not have the plastic arm.
This is picture of replacement I installed. Original had smaller plastic (not large round dial) arm type. I learned the hard way that it needs to be installed properly.
When I was looking for replacement, I bought a few pump/cover that were to be the pulse/intermittent wipers. One we verified the 84 it was removed from had the intermittent blinker. However when I opened it, the cover was standard non pulse.
I've been chatting to the guy who's offering that cover and we're both aware that the cover shown won't work because the arm is missing. Thanks very much for the heads up though - much appreciated.
I do keep punching that part number into eBay. Maybe I'll get lucky. It's crazy how hard these covers are to get, especially considering literally millions of cars had them fitted!
Car: 1989 Pontiac Formula /1985 Trans Am
Engine: TPI 350 / TPI 305
Transmission: 5 Speed / 4 Speed Auto
Axle/Gears: 323
Do you still have this cover?
Sorry, I bought it and it's now fitted to my car.
Good luck with the search, these are tricky to find but they're out there!
If anyone has one of these covers that is mechanically intact, I'd like to get measurements. I don't care if the circuit board works or not. I'll 3D print the plastic & redesign the circuit board. I need to know the sizes & pin-outs first though. I'll be doing the same thing with the headlight control board too. randyrho at yh
87IROC-Zrebirth
01-06-2017 07:53 AM
