Slave Cylinder Cut Out from Cowl
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Looking for the area of sheet metal including the slave cylinder cut out hole from the cowl area if anyone is parting a 5 speed car out. Thanks.
Re: Slave Cylinder Cut Out from Cowl
Nothing too special about it, save the photo I posted here - https://www.thirdgen.org/forums/tran...ml#post6220466
Blow it up to size, and you'll be able figure out where to drill the holes, and make a pattern to cut a doubler plate from steel. The hole in the firewall is full round, the hole in the doubler is oval shaped to match the clutch master gasket.
Car: 85 Iroc-Z
I may try a plate from your image. The old hole isn't the greatest.
tmork454
08-15-2013 03:45 PM
New2Chevy
12-09-2012 11:15 PM
dixiebandit69
05-27-2008 02:06 PM
