Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
2nd Gen filler point in a 3rd Gen bird
Old Mar 10, 2004 | 08:49 PM
JCherwien's Avatar
Car: 1984 Autoform Firebird
Engine: 2.8l V6
Greetings,
I had a thought the other night...On my convertible, the rear trunk key spot doesn't do anything anymore, as the hatch is opened only by the hatch popper (Custom job as part of the convertible conversion), and I was wondering if anyone has every moved their fuel filling spot to behing the center panel like on a 2nd gen bird...I was thinking about dropping the old tank, and putting a summit fuel type cell in the rear, and was thinking it would be pretty cool to have the neck end-up at the back...
Has anyone done anything like this?
Miah
Old Mar 21, 2004 | 10:02 PM
MikeS's Avatar
Nope, never tried it. However, I imagine that the depth of the "hole" in the back of our cars would give you some problems. It seems like your filler neck would have to come through forward sheet metal of the hole into the interior of the car and then through the back sheet metal to your outside access. Sound right to you?
Old Mar 22, 2004 | 08:38 AM
JCherwien's Avatar
Engine: 2.8l V6
Kind of...Pretty much. I was going to drop the old tank, and run new lines to the cell, which I was going to put i the storage well in the very back...So I didn't think it'd be too far to that panel...But, good to know anyway...It'd probably be more work than it's worth...
Thanks for the input!
Miah
Old Apr 2, 2004 | 01:50 AM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
thatd be cool if you did it. the best part of having it in the back is not having to pull in one way at a gas station, just pull in anywhere
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Warlocksirix
Sep 3, 2015 12:26 PM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
