Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
differential cover
Old Mar 26, 2004 | 09:15 PM
Mathius's Avatar
differential cover
Could one fabricate a new differential cover or do they have to be a certain shape to retain the proper amount of fluid?
Mathius
Old Mar 26, 2004 | 10:50 PM
camaro_1983_383's Avatar
you could make one as long as it didnt use less fluid than stock. the fluid not only lubes but cools as well, so to little fluid and your rear could overheat. but if it held more fluid, it could be better because your fluid would not be as hot. the main deal with rears is fluid level, which would not be changed by a new cover, because the fill hole is still in the same place.
Old Mar 27, 2004 | 05:02 AM
ede's Avatar
ede
i doubt if you could really make it too small and reduce the amount of oil in the rear. you'd have to make it so it cleared the gears.
Old Mar 27, 2004 | 07:16 AM
Mathius's Avatar
This was my thought too, but will too much oil hurt it?
Mathius
Old Mar 27, 2004 | 12:26 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Mathius
Nope, more oil would increase the heat dissapation and let the differential live a longer happier life. Its just a gear set that turns around along with some bearings nothing special.
Old Mar 27, 2004 | 03:32 PM
Mathius's Avatar
Any reason I couldn't make one out of 6061 aluminum?
Mathius
Old Mar 27, 2004 | 08:20 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
it may bend if its made of aluminum and isnt like braced
i would put some strips ont he outside weld them on and then add 2 holes and yea u should be set. send me some pics when u get done will ya
Old Mar 27, 2004 | 08:46 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Mathius
nope
(yea i know, wrong rear... but they make a 10 bolt one)
Old Mar 28, 2004 | 06:47 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
What about the 9 bolt?
Old Mar 29, 2004 | 07:10 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
read this thread for the latest info on TAs 9bolt cover
Old Apr 21, 2004 | 01:39 AM
HamsterOnaMission's Avatar
if you have steel in contact with alluminum, and its a daily driver, your going to have some problems with rust
Old Apr 21, 2004 | 07:57 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
umm... ok.
i guess all of us are going to have to pull the steel bolts out of our alum heads, and take apart almost every alum part in our cars...
no. dissimilar metals do create mild electrical current and can become stuck together over time, but nothign like that is going to happen to the rear end.
Veaceonee
Sep 29, 2016 08:15 PM
dbrochard
Jan 28, 2016 08:42 AM
dbrochard
Sep 19, 2015 08:13 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
