Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
millermatic 251 to tig ?
Old Apr 11, 2004 | 08:12 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I was thinking about getting a miller tig spool gun for my 251 mig welder and was wondering if any one has this setup and how well does it work? I know it needs a differant gas mixture and a polarity change as far as setup goes but, is it a good product?
Old Apr 12, 2004 | 03:50 AM
ede's Avatar
ede
don't think there's a tig spool gun. maybe a mig spool gun.
Old Apr 12, 2004 | 02:54 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Spool guns are used primarily to weld alluminum because the wire is so soft it often binds and bunches up through a regular mig gun with a long cable. The spool gun eliminates that by reducing the wire travel to within a few inches from the weld.
Old Apr 13, 2004 | 04:52 AM
ede's Avatar
ede
whqat are you wanting to do? run soft wire or run hard wire? if you're wanting to run soft wire in a mig gun use a teflon liner and increase the tip size by .010 or so. keep the gun as straight as you can and you may not need the spool gun. best set up for sofe wite mig welding is something like a cobramatic, push/pull gun feeder set up.
Old Apr 16, 2004 | 09:47 PM
Engine: ls1, LB9
I just want to run the soft wire (aluminum) all I want to know is if the spool gun is a good built unit. they look kinda cheap quality in person. and how well they work.
no one here has the miller spoolgun?
Old Apr 17, 2004 | 06:12 AM
ede's Avatar
ede
miller makes very good products. their spool gun would be fine.
Old Jul 2, 2019 | 07:05 PM
Wascl's Avatar
Re: millermatic 251 to tig ?
I have a spool gun for my Miller matic 251 and it works great for welding aluminum. I haven't had any issues with it. I just have to remember to adjust at the spool gun instead of the welder. lol
Old Jul 2, 2019 | 09:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You'll also need 100% Argon to weld aluminum. The CO2 steel mix isn't a good enough shielding gas.
Old Jul 5, 2019 | 02:38 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Sucks they had to wait 15 yrs for an answer.
Old Jul 9, 2019 | 10:04 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The way my machine is set up, the speed control on the machine changes the spool gun feed. I assumed the millermatic was the same way ?
I don't even use TIG anymore. Spool gun and 100% argon. Intakes, trailers, brackets - welds them all.
-- Joe
anesthes
Aug 24, 2015 08:18 PM
Gumby
Aug 29, 2005 01:36 AM
V8Astro Captain
Mar 31, 2003 01:20 PM
John Millican
Jan 4, 2003 11:00 AM
Val
Sep 19, 2000 09:26 PM
