boxed lcas
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
boxed lcas
i promised those of you who wanted to see some boxed lcas that i would get a picture and here it is. i did this with a stick welder...my first time too. i think they turned out great!
you should drill some holes in them , just like 2 in each one, just incase some water gets in there. I think their are two holes in the top of them . I dont remember but put some small hole sin them . good work , they look good.
Car: 1986 camaro
Engine: 383 sbc
i used 1-1/4 inch flat rebar that was about 1/8th thick as mentioned earlier.
Car: 1986 camaro
Engine: 383 sbc
when i did this i ground the underside edges of the rebar to make the bar sit flush with the lca. then i welded them. if i didnt grind the edge down the rebar would have stuck up a little. i wanted it flush.
Transmission: 4L80E/4L80E
Originally posted by pecha
Just gotta convert it to milimeters and I'm ready to go
That's probably a little thicker than necessary. If you mic the LCA, that's all the thickness you need.
