Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
suicide doors?
Old Apr 22, 2004 | 09:18 PM
Kaas's Avatar
Car: 89 Iroc-Z
suicide doors?
heya guys..was just wondering how hard it is to get suicide doors on a thirdgen camaro...and if it isn't that hard, is it easy to get shaved handles on em too?
Old Apr 23, 2004 | 10:34 PM
Mathius's Avatar
Shaved handles would almost have to be a must, because you'll most likely have to completely replace the stock door latches. First off, you'd need to re-enforce the frame with subframe connectors, and most likely a rollcage or something of that nature because the b pillars aren't used to supporting the weight of a door, and it would probably cause major frame twisting.
You're talking major bucks to have a shop do it, but it can be done. If you can weld, cut, and fabricate, it probably wouldnt' _cost_ too much if you can get a good deal on steel, but it would still require major fabrication.
Mathius
Old Apr 25, 2004 | 09:53 AM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
GO TO AUTOLOC.COM THEY HAVE A KIT FOR SUICIDE DOORS..
Old Apr 25, 2004 | 07:56 PM
Mathius's Avatar
If you install autoloc's kit on your car, you're going to be crying within a year. Autoloc's kit is latches and hinges, and will not properly re-enforce your subframes to handle the reverse weight of the doors.
Mathius
Old Apr 26, 2004 | 12:05 AM
Adrenaline's Avatar
Car: 92 Camaro RS
if ur interested in a pic here it is, if not, just ignore me
Old Apr 28, 2004 | 01:10 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
suicide
did you do the suicide install your self ?? and if so was it a big deal?? do give some details please...
Old Apr 30, 2004 | 07:12 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
i think suicide doors would look totally awsome on a third gen and that pic is an awsome example of it
very cool man ........
Old Apr 30, 2004 | 10:05 PM
robsgta's Avatar
doors
Can you show us a pick of the hinge modifcation I want to do either the suicide doors on my car or the Lambo...doors being that it seems no one has done it yet it seems
Old May 1, 2004 | 02:09 AM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
That pic is 3 or 4 years old, if not even older.
Basically suicide doors are set up just like normal doors. The only difference is that the hinges are swapped around along with the striker bar. To be properly done you'd have to re enforce doorjamb on the rear quarter panel to cope with the weight of the door. It woudl suck to go thru all of that trouble to warp the crap out of the rear quarter panel. Just off the top of my head you'd have to use a different style of hinges to get the door to clear the quarter panel when the door is opened.
Old May 1, 2004 | 02:55 AM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
aw! it wants a hug!
Old May 3, 2004 | 10:55 PM
jay92,85,79's Avatar
Car: 85z28,
That looks prettycool..But make sure u have the latches work right.Sure would suck to be drive down the highway at about 75 80 or so and the dam doors go flying off lol
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
kkirch15
Sep 30, 2015 04:44 PM
