Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Control Arms
Old Apr 26, 2004 | 09:56 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Control Arms
Recently made some control arms.
4130 Chromoly Steel.
Overall, not too bad in my opinion.
Friend did the cutting and welding, I did the powdercoating. Overall all they came out well. Now on to the panhard and torque arm.
Old Apr 26, 2004 | 10:08 PM
jonarotz's Avatar
Car: 91 Z28
What are you going to do for bushings?
Old Apr 26, 2004 | 10:09 PM
Ions91Z28's Avatar
I've already have bushings, but if not, I'd purchase some.
They aren't terrible in price.
Old Apr 26, 2004 | 10:21 PM
jonarotz's Avatar
Car: 91 Z28
I mean what kind are you going to use? Sorry I wasn't clear enough. Are they set up for stock ones?
Old Apr 26, 2004 | 10:25 PM
Ions91Z28's Avatar
Energy Suspension bushings.
I assume the stock ones would work as well.
Old Apr 26, 2004 | 10:31 PM
jonarotz's Avatar
Car: 91 Z28
what is the inner diameter of the tubing used on the ends?
Old Apr 26, 2004 | 10:41 PM
Ions91Z28's Avatar
Hmm, I'd have to go measure it again... or do the math.
O.D. is 1.5", thickness is .095. That's for the part that holds the bushings.
Old Apr 27, 2004 | 09:14 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i made my own to but i used the stock arms. arnt the bushing holes different sizes on each end to accomodate the stepped surface of the bushing?? that was why i stayed aways from making tubular ones. i was afraid the bushing wouldnt be snug on both sides.
Attached Thumbnails Control Arms-fabricated-rear-lcas-528
Old Apr 27, 2004 | 11:26 AM
Ions91Z28's Avatar
Not sure, these are the exact same size as BRM control arms, in terms of bushing areas. The control arm main tube is 1.25"x.095"
Old May 4, 2004 | 12:33 PM
Outlaw87's Avatar
Car: 2002 Camaro SS
Engine: LS1 350 V8
Transmission: Automatic 4 Speed
That is pretty cool.
Hotrodboba400
Dec 10, 2019 07:07 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
