Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Metal Fabrication Question
Old May 23, 2004 | 01:55 PM
89RSOwner's Avatar
If an object is around 70 #'s, and has it's wieght supported by a bracket, and have a set range of movement. What would be a good size metal to use? Let's say that the bracket is a bit on the not so wide side, (U-shaped - 3 pieces - 2 X 1/12 each piece) would 3/16 and a good weld be enough?
Old May 23, 2004 | 03:09 PM
ede's Avatar
ede
i'd say yes but it'd help if you provided more details.
Old May 27, 2004 | 07:11 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
50,000 lbs good enough?
Done correctly, the weld will have a strength similar to the base metal or weld filler. Assuming 50 ksi... Figure out the area of weld (for fillet welds, multiply by .707 to get the thinnest part of the fillet). If you have 3 * 2.5" worth of 3/16" wide fillet welds, the weld will hold 3 * 2.5in * .1875in * .707 * 50,000lb/in^2 = 49710 lbs. Weld on the brackets so the welds are in shear (think 2 pieces of paper trying to slide across each other) rather than in tension or bending. If you put funky bending loads on the welds, use poor material, bad welds, etc, the capacity will be much less. Generally all welds are done overkill.
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
NiG
Sep 2, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
