Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Best welding process for cyl heads?
Old Jun 19, 2004 | 06:59 AM
oil pan 4's Avatar
Car: 89 Firebird
What would be the best welder to weld in cc's on a cast iron cylinder head?
I have a miller 135 amp welder with only flux core steel wire for now. I have a spool of .025'' mild steel and a spool of 308 in .023'' in the mail and am going to get some more Argon here soon.
should I get some .035'' 316 SS and maybe that will work?
I don't think shealded mild steel or SS beads will do it.
Do I need a stick welder for this?
So far I haven't had good luck with cast Iron and the flux shealded .035'' wire. I know it's not ment to be with those 2.
Old Jun 19, 2004 | 07:32 AM
ede's Avatar
ede
i'd use Ni filler and GTAW (tig)
Old Jun 20, 2004 | 10:17 AM
ljnowell's Avatar
Why exactly are you welding? If it is to repair a crack, I have my favorite method. I usually take a six inch long piece of iron, and weld it to one end of the head that is cracked. Then I use this handle to throw the thing in the trash.
Old Jun 21, 2004 | 07:17 AM
oil pan 4's Avatar
Car: 89 Firebird
I was just looking to change the shape a little.
Old Jun 21, 2004 | 12:00 PM
ljnowell's Avatar
Ok I gotcha. So are we welding in some compression?
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
fasteddi
Sep 2, 2015 10:29 AM
michealleger
Aug 26, 2015 03:29 PM
