Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
how to make a hat
Old Oct 14, 2004 | 12:31 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
how to make a hat
wanna make a carb hat for my turbo project
Old Oct 14, 2004 | 07:48 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Get some sheet metal, w/ a compass, trace a circle for the top hat, cut it out, do the same for the bottom but w/ an inner circle for the carb diameter, cut it out, and then cut a strip to connect the two. Weld a bead along the strip to join it to the top and bottom plates. Drill a hole in the center to run the aircleaner stud through it. Take a piece of 3" tubing (or whatever you're using for the intake piping), bellmouth it to fit the carb hat OD, and weld that to the hat. Drill/Mill/Grind/Cut out the center of where you welded it. Depending on your boost and material thickness, you might need to reinforce it. You're finished. This will take anywhere from 1 hour to a weekend, depending on your competence with metalworking.
The nicer way would be to hammer form a torus shape for smoother airflow, but if you could do that, ya wouldn't be asking here.
3rd alternative is to call Turbonetics w/ a credit card, and $80 later, you get one from UPS.
Old Oct 14, 2004 | 09:59 AM
ede's Avatar
ede
i made one for jester once, painted it pink and added a little metal tab with a message on it for him. think if you searched over at www.nethirdgen.org you might find a pic of it.
Old Oct 14, 2004 | 12:08 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
If you're keeping the boost moderate you can use a plastic one off a TBI Caddy or Dodge motor.
Old Oct 17, 2004 | 08:10 PM
jocww's Avatar
im thinking around 6 psi
Old Oct 18, 2004 | 12:27 AM
jocww's Avatar
great j are you saying that i can take a k&n filter type would that work.
yyyyyeaaa 1111 posts all ones
jon
Old Oct 18, 2004 | 07:22 PM
TheGreatJ's Avatar
No, I'm saying you can go find an 80's Caddy with a 4.1, 4.5, or 4.9 FWD motor and take the TBI hat off it and stick it on your carb. The flange is the same. A lot of dodge trucks with TBI had a hat that will work too, in particular look for V6 Rams and Dakotas from the early-mid 90's.
Old Oct 18, 2004 | 08:07 PM
jocww's Avatar
ok thanks
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
