Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Creating my own gauge panel for Autometer gauges Part 2
Old Jan 3, 2005 | 12:45 AM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Ok, I FINALLY got some pics for you guys. Mods, please don't delete these pics. I know that there are more than 3, maybe we can make it a sticky/useful info post?? If it is a problem, I can make multiple posts in succession with more pics.
Anyway, here is the first pic. It is the raw material that I am working with. It is some type of fiberboard with a black plastic facing that is textured.....
Attached Thumbnails Creating my own gauge panel for Autometer gauges Part 2-clusterboard1.jpg
Old Jan 3, 2005 | 12:47 AM
paulmoore's Avatar
I simply took the factory black plastic gauge panel cover, and traced the outline onto the back of the fiberboard and got this....
Attached Thumbnails Creating my own gauge panel for Autometer gauges Part 2-clusterboard2.jpg
Old Jan 3, 2005 | 12:49 AM
paulmoore's Avatar
The next step was to put boxes around the circles like so...
Attached Thumbnails Creating my own gauge panel for Autometer gauges Part 2-clusterboard3.jpg
Old Jan 3, 2005 | 12:51 AM
paulmoore's Avatar
After the boxes were drawn, I measure the height and width of the boxes, and made a mark at the halfway point. Then I connected the lines to find the true center of the circle.....
Attached Thumbnails Creating my own gauge panel for Autometer gauges Part 2-clusterboard4.jpg
Old Jan 3, 2005 | 12:55 AM
paulmoore's Avatar
Since I am using a 5 inch tach and speedo plus 2 1/16 gauges I had to do some spacing. For the tach and speedo I simply found the center point of the circle, measured down 1//2 inch, and then out 1/2 inch and redrew the circles with a compass. The smaller gauges were moved by 1/4 inch as seen in this pic....
Attached Thumbnails Creating my own gauge panel for Autometer gauges Part 2-clusterboard5.jpg
Old Jan 3, 2005 | 12:57 AM
paulmoore's Avatar
With the true center of all the holes found in their new adjusted locations, I can use the holesaw to cut them out....
Attached Thumbnails Creating my own gauge panel for Autometer gauges Part 2-clusterboard6.jpg
Old Jan 3, 2005 | 01:00 AM
paulmoore's Avatar
Now all I have to do is cut out the outline of the panel. I don't have any plans to use the warning lights or anything, and as for the turn signals I think that I will use some green LED bulbs. Here is the finished product.
I am sorry that I don't have any Autometer gauges to put in this panel yet and I don't have any pics of it in the car but at least you guys can get an idea of what it took to make it.
Attached Thumbnails Creating my own gauge panel for Autometer gauges Part 2-clusterboard7.jpg
Old Jan 3, 2005 | 11:29 AM
82TAusmc's Avatar
Car: 1982 Pontiac Trans Am
where and how much is that fiber board????just curious
Old Jan 3, 2005 | 12:15 PM
paulmoore's Avatar
It actually came from my toolbox. I have a Matco double bay toolbox, and that material sits on top of the toolbox so that you can write on it, work on it etc. I had an extra piece leftover when I bought my hutch because the piece that came with it was smaller to fit inside. I simply used thie extra piece for this project. I actually talked to my Matco tool guy, and he said that I can get the liner for about $20. the board itself is about 4 /12 feet by 3 feet. the board is big enough that you could make about 8 of these cluster panels.
Old Jan 5, 2005 | 08:01 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Sweet!I just made damn near the same thing..guage sizes also!Check it out..
https://www.thirdgen.org/techbb2/sho...hreadid=273291
Old Jan 9, 2005 | 11:17 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
man, i just took my old 3rd gen setup out of the car, i could have sold it to you. looking good!
Old Jan 12, 2005 | 02:12 PM
89firechicken's Avatar
looks like you might have a problem with the gauge rims touching on the center cluster
Old Jan 12, 2005 | 03:44 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
this would actualy make an awsome sticky!! nice job man
Reddeath210
Oct 6, 2015 08:20 AM
355sbcTPI
Aug 19, 2015 04:38 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
