Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
parking brake relocation
Old Feb 16, 2005 | 03:06 AM
Kandied91z's Avatar
i'm looking to relocate my parking brake. i'd like to at least move it over slightly to a similar location much like the c5 style. i'm building a custom center console and would truthfully like to relocate it entirely to either the drivers side door area like a c4 or even a pedal assembly much like a stock g body similar to that of a grand prix or otherwise.
anyone have any suggestions on how to go about this and not loose the stock properties?
Old Feb 16, 2005 | 08:29 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
post pics if anyone has any....
Old Feb 16, 2005 | 09:16 AM
KAOSRacing's Avatar
I've never done it nor have I put any real though into it but since it's all cables it shouldn't be that hard.
Figure out where/how you're going to mount your lever/pedal to determine where you need to make the hole to pass the cable through. Then determine the path of the cable so that you can place mounting/guide hardware. Then you have the length of cable needed and can start figuring out what car had a cable of the correct length with the correct ends on it.
I'm willing to be the "which cable fits" research part is going to be the longest and hardest part.
Old Feb 16, 2005 | 07:01 PM
Kandied91z's Avatar
i'm willing to make a new cable if need be. i just don't want to comprimise the stock intended purpose just to move it.
does the parking brake on a 91 rear disc adjust the rear brakes like those of earlier years or is it pretty much a straight forward parking brake?
Old Feb 17, 2005 | 09:27 AM
KAOSRacing's Avatar
As long as everything is tensioned properly and pulls in the correct direction, I don't think you'll compromise anything.
The PBR calipers operate the parking brake differently than the cast iron calipers. I'm not even certain that the parking brake cable (the one that goes from the lever to under the car) on the aluminum caliper cars have an adjustment on them, I know the 4th gens didn't.
Old Feb 18, 2005 | 07:20 PM
83 Crossfire TA's Avatar
The 4th gens used an automatic ratcheting adjuster assembly inside the console as part of the lever pivot. Sometimes you can confuse them and you’ll be able to pull up the PB lever all the way with no tension (I had it happen once about a week after I bought my ’97 WS6 and then never again)
The under car adjuster on teh 3rd gen setup is only supposed to compensate for brake cable stretch, the rest is supposed to be done by the rear brakes self adjusting
Old Feb 18, 2005 | 07:27 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i was looking thru my lokar catalog and they have great emergnecy brake kits..... u can use one of thier kits to relocate it... it comes with everything u need to do it... the lower foot brake is chrome and looks good! www.lokar.com my price says they are around 131.00 dollars....
Old Feb 19, 2005 | 02:50 AM
Kandied91z's Avatar
thanks guys i'll have to look into it then, i need to get one of those lokar books.
Old Feb 19, 2005 | 08:57 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
u can order one free on their website, great stuff!
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
