Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Making an AFPR?
Old Mar 23, 2005 | 06:58 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Making an AFPR?
Any one seen the AFPR tech article on the 3rd Degree website? Does that work good? Any comments or concerns? Thinking about doing it just wanted some feedback before i drill a hole through my current FPR. Thanks
Old Mar 24, 2005 | 02:16 AM
onebinky's Avatar
Yes, it works. Many on here have done it with success, and I am going to do it one of these upcoming weekends. All you are doing is adjusting the spring tension on the regulator, as long as you follow the directions you shouldn't have any leaks.
Old Mar 24, 2005 | 09:26 AM
trueburton's Avatar
thanks sounds good i'm doing it today.
Old Mar 24, 2005 | 11:09 PM
83 Crossfire TA's Avatar
Picture, 1000 words, yada yada… 3000 words:
Old Mar 27, 2005 | 10:15 AM
Vader's Avatar
Oh. A modified "T" nut. There's a good idea. Saves a little space I suppose. Should be plenty strong.
Old Mar 27, 2005 | 02:23 PM
Yep, just break the points off with a pair of piers and JB weld it in place. If you didn't notice, I also hammered out the contour in the end of the fpr cover to give a little extra room for the washer. With a little creativity you can actually get this to go a little lower the stock pressure if that’s what you need, but I would focus on the area that you really need to be adjustable in because there isn’t much room between this thing and the bottom of the plenum. In my case I ground out a little hollow in the bottom of the plenum to give me a bigger adjustment range and room to use a ½” wrench on it.
If I took some time I could have probably made it look a little better, but the original that I started with was all rusted to hell and I was doing this on a Friday afternoon and trying to get it reassembled before T&T that night.
Old Mar 27, 2005 | 11:54 PM
onebinky's Avatar
not bad at all
Any issues with using the epoxy instead of welding or brazing?
Old Mar 28, 2005 | 12:07 AM
If there was I would have run a tig bead instead... it's the same now as it was 3 or so years ago when I did it
Bubbajones_ya
Aug 31, 2015 12:02 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
