Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Guages in the AC and heater control panel
Old Jun 3, 2005 | 01:18 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Hey everyone, I was wondering if anyone has ever taken out the AC and Heater control panel and put gauges in it. If so please help me out and show me a pic or tell me out to get them in there the best way possible. Thanks for all your help.
Old Jun 4, 2005 | 01:43 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I did it. Dont have a pic but what I did was take a thick peice of plastic that kind of matched the dash and cut it out so three 2 1/16 autometer guages fit. It was quiet easy so dont be intimidated.
Old Jun 4, 2005 | 11:15 AM
BT283's Avatar
It just seems that the hole for the heater controls is a little smaller than 2 1/16. Is it not??
Old Jun 5, 2005 | 02:22 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
grover, where did you get the plastic your talking about?
Old Jun 5, 2005 | 02:45 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I got the plastic from a black tool tray I had in my garage. There is plenty of room you just have to cut it out so there is no overhang which makes the hole smaller. Just cut the hole out where the plastic makes it smaller. Do you get what I am trying to say? Dont have any pics cause I did this to my old car.
Old Jun 6, 2005 | 10:28 AM
BT283's Avatar
I think i can do it but i am trying to use aluminum. Any reason i shouldnt use aluminum??
Old Jun 6, 2005 | 11:57 PM
mw66nova's Avatar
Engine: 7.0L
only because it's hard to paint and make it look right, and if it's not painted, it looks like a crappy thrown together bracket car...other than that, it's a great idea!
Old Jun 7, 2005 | 01:02 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
i went one step further and replaced the plastic piece that holds the radio also. made it one piece and mounted guages, radio and kill switches. i laid the old pieces over the aluminum and scribed the outline and mounting holes then cut my stuff in then took an orbital sander with a small disc to the aluminum which gave it a kool look then clear coated it. doing the same thing to inst. cluster now.
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
Jlanz55
Sep 6, 2015 02:35 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
