Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Homemade shorty Headers and dual cat.
Old Aug 21, 2005 | 05:15 PM
JERRYWHO's Avatar
I had SLP 1 3/4 headers with factory cats and wanted 1 7/8 shorty headers with 3 inch cats, So this is what happens when you have to make them.
Jerry
Old Aug 21, 2005 | 05:16 PM
JERRYWHO's Avatar
One more picture.
Jerry
Old Aug 21, 2005 | 05:32 PM
Firebat's Avatar
nice. i wouldn't mind having some 1 7/8 shortys.
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Someone finally made something worth a ****! Nice. Looks like you did a nice job. Gotta ask though, what are you building that justifies an 1 7/8" header primary? And also, why were you set on a shorty style header?
Old Aug 21, 2005 | 05:35 PM
KillerRS's Avatar
:werd:
Old Aug 21, 2005 | 05:52 PM
JERRYWHO's Avatar
My car is used in California and needs to look smog legal. The new motor is a 412 Rodeck with Dart pro 1 heads.
Jerry
Old Aug 21, 2005 | 06:26 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Excellent work
Old Aug 21, 2005 | 11:20 PM
ckeene502's Avatar
that is very nice!!!!! good work there, wish i could do things like that
Old Aug 22, 2005 | 09:53 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Wow that is great work. Do you make these kinds of things all for a living? I am looking for an exhaust for my 500 HP 383. I am thinkin of LTs and dumping it. But if I could get my hands on somehting like that I would be in better shape. I don't need cats though.
Thx for any insight.
Old Aug 22, 2005 | 07:07 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Those are the cats a$$! You should seriously look at making these for a living
Old Aug 22, 2005 | 07:09 PM
Firebat's Avatar
if i ever get a 383 i will be begging you to make me a pair
Old Aug 22, 2005 | 10:39 PM
TexasLT1's Avatar
Car: '92 RS
beautiful. thats craftsmanship right there.
Old Aug 23, 2005 | 08:18 AM
JERRYWHO's Avatar
Originally posted by KillerRS
:werd:
That's me.
Jerry
Old Aug 23, 2005 | 11:11 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
ABSOLUTELY!
Fantastic work, Jerry
Old Aug 24, 2005 | 11:23 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Thoes are bad as hell, did you use the SLP headers as a template?
Old Aug 25, 2005 | 12:08 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
those are one hell of a sweet setup
Old Aug 25, 2005 | 12:35 AM
laiky's Avatar
WOW! i am impressed.
can you post details of how you made them? Where did you get the tubing? Pre-bent ? what is the parts list? how big are the Y pipes? Are there any fitment problems?
Old Aug 25, 2005 | 12:41 AM
JERRYWHO's Avatar
My headers are very differant then SLP. See the drivers side collector is pointed back and the drivers side pipe runs under the torque converter, You can only do this if you run a 9" torque converter ( I have a "Yank super stock 3600" in the car) The drivers side is about 1" from the steering shaft and a lot of SLP installs it hits. With SLPs the number eight plug will hit the number six tube with some aftermarket aluminum heads and not with my headers. I will post a picture with both so you can see all the changes.
Jerry
Old Aug 25, 2005 | 01:25 AM
357transam's Avatar
Car: 1986 T/A
Engine: 350 bored .040, s/r torquer heads
Transmission: 700r4, tci shift kit
Axle/Gears: stock borg warner
beautiful job! I bet they are a pita to get into the car though, and what kind of clearances do you have on the passanger side with the cats mounted there? The shop i took my 86 T/A too did basically the same thing without the cats, and it sticks down another inch and a half or so when its on the car.
Old Aug 25, 2005 | 02:38 AM
Car: 89 Formula
Oh yeah i guess i should have paid more attention to the pictures
Old Aug 28, 2005 | 04:16 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Jerry
Very nice work. You must have a few hours tied up in those. I like your choice for a header to pipe connection. If you can get at them it should make f'ing around with collector bolts much easier.
Cudo's to your fabricating skills!
Old Sep 1, 2005 | 01:05 AM
MIKEYDZ28's Avatar
you deserve even more credit. that is extremely impressive. you make some major bank on putting those together, i know id buy a set...
Old Sep 1, 2005 | 10:17 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
Old Sep 6, 2005 | 11:21 AM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
My dad is a welder/fabricator and he couldn't get over those headers. Great Job man. Now to just get them coated.
Old Sep 6, 2005 | 12:04 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you know, if you wernt in cali, you could have a killer turbo car now.... lol.
Old Sep 6, 2005 | 09:58 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Those are great looking headers man!! Right on. Like others have posted did you start out with a kit or do all the bending yourself?
Bill
Old Sep 6, 2005 | 11:28 PM
JERRYWHO's Avatar
Bill
I started with a set of flanges, collectors, eight 1 7/8 U bends and two J bends.
You can get them at http://www.schoenfeldheaders.com/product.htm
The rest is up to what you can fit in the car.
Jerry
Old Sep 6, 2005 | 11:48 PM
Did you do any pipe bending yourself of did you just cut and weld different pieces together?
Bill
Old Sep 7, 2005 | 01:35 PM
JERRYWHO's Avatar
Bill
All I did was just cut and weld parts of U & J bends. I don't have a 1 7/8 die for my bender and the die set is way more then the $125 for all the 1 7/8s prebent tubing. The sad part is I have 1, 1 1/4, 1 3/8, 1 1/2, 1 5/8, 1 3/4 and 2" die sets.
Jerry
Old Sep 7, 2005 | 04:15 PM
laiky's Avatar
are they stainless? looks like it in the picture but the link only has mild steel.
Old Sep 7, 2005 | 05:10 PM
JERRYWHO's Avatar
Originally posted by laiky
are they stainless?
No...Just mild steel and will be coated.
Jerry
Old Sep 7, 2005 | 07:11 PM
right on I am going to try to do something like that.
Bill
Old Sep 7, 2005 | 08:03 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Sweet work Jerry. Are you a fabricater by profession?
Old Sep 12, 2005 | 02:59 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Those look nice.
I can see what u mention about improving on the SLP design lol
Judging by te outward sweep of the pipes before they curve back down and in, u can actually chang eplugs fairly easily too
nice work
later
Jeremy
Old Sep 12, 2005 | 06:44 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
did u build those on the car?
how about making the rest of us a set of those?
Old Sep 21, 2005 | 03:35 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
nice , where abouts are you in cali?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
aharvel50
Sep 21, 2015 07:31 PM
jer4251
Sep 16, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
