Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Making your own SFC's??
Old Nov 15, 2005 | 06:02 PM
86iroclamarque's Avatar
Car: 1986 IROC
Engine: 305ci DEAD FINALLY! 350 almost ready to go in!
Transmission: 700R4/Coming out TH-350 going in!
Does anyone have a pattern or plans for making your own SFC's? It couldn't be that hard, right?
If I had a pair to go by I think I could do it.
Old Nov 15, 2005 | 06:22 PM
bitchin85camaro's Avatar
Car: 85 camaro
Engine: 327
Transmission: 350, 6200 stall, w/ brake
Axle/Gears: soon to be strange 5.14
talk to people at a local welding shop. im sure they weld in home made sfc often.
Old Nov 15, 2005 | 08:05 PM
IROCZ86's Avatar
Car: 96 SS #15
Engine: LT 1
Transmission: M6
Axle/Gears: 3.42 ZT
Not really that hard, all you have to know is what points on the bottom of the car you need to connect and you just connect them.
Old Nov 16, 2005 | 12:21 AM
darakus's Avatar
Car: 1988 Trans Am GTA
Transmission: 700r4 rebuild, heavy duty clutch pa
If this helps :
http://www.spohn.net//index.cfm?acti...d&contentid=10
They show pics of their sfc's welded to f-body.
Old Nov 16, 2005 | 04:31 AM
ede's Avatar
ede
if you have the skills to make them you don't need plans. parts just need to go from point A to point B and you get to pick where point A and B are.
Old Nov 16, 2005 | 05:12 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I have a set of Hotchkis SFC's. They run from the rear control arm bracket to the front subframe. If there is one thing a put on my car that helped the most, I would SFC's are a MUST HAVE!!! Check these out they are awesome.
Old Nov 16, 2005 | 09:01 AM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
I'm sure you could measure, cut, contour the pieces so they sit flush with the floor of the car- at least as good as any of the aftermarket pieces anyway. You could just go through the floor like I did. There was a couple of rust holes I wanted to fix anyways so I didn't care about cutting up the floor.
http://www.81x.cc/Authors/83fbody/DCP_2265.JPG
http://www.81x.cc/Authors/83fbody/DCP_2266.JPG
Material is 2x3" 1/8" thick, depending on where you plan to connect the frame rails I think that 2x2" would work very well for the perimeter style sfc's.
Old Nov 16, 2005 | 09:02 AM
Car: 1986 IROC
I just don't know where they go.
Old Nov 20, 2005 | 11:52 AM
rgauder's Avatar
Car: 1987 Trans Am
1983Fbody, do you have any pics from underneath the car? Thanks.
Old Nov 21, 2005 | 09:43 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
I had asked about sfc's before and someone put up this pic. It helped me out with mine. I don't remember who it was but I have not seen a view like this to help out with figureing out what to do before.
Attached Thumbnails Making your own SFC's??-under-side-view-f
Old Nov 22, 2005 | 09:41 AM
Car: 1986 IROC
This is exactly what I looking for!!!
I can't thank you enough!
Old Dec 13, 2005 | 05:35 PM
Ratchet's Avatar
this is a link to an old post of the ones I made.
https://www.thirdgen.org/techbb2/sho...hreadid=189705
I tried to find a post by SERPENT99 he used this idea and did a way better job of fabbing them up. His post is there but the pics don't show anymore.
Ric
kairles
Oct 26, 2015 09:13 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
