Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
driveshaft
Old Nov 17, 2005 | 10:45 PM
TexasLT1's Avatar
Car: '92 RS
driveshaft
how's this for fabrication?
3" x .083" stainless pipe with 1350 weld yokes and U-joints
Old Nov 17, 2005 | 11:28 PM
rgauder's Avatar
Car: 1987 Trans Am
How did you balance it?
Old Nov 17, 2005 | 11:49 PM
TexasLT1's Avatar
Car: '92 RS
took it to a driveshaft shop in Houston.
Old Nov 18, 2005 | 12:56 AM
83 Crossfire TA's Avatar
where did you get the yokes?
Old Nov 18, 2005 | 09:27 PM
Bones232's Avatar
Car: 1991 Camaro RS
Engine: 355 Vortec TBI
Nice welds... did you weld it on an orbital?
How heavy is it compared to the chrome-moly?
I love the shine of stainless. Nice job
Old Nov 19, 2005 | 12:13 PM
TexasLT1's Avatar
Car: '92 RS
yokes are from www.driveshaftsuperstore.com
welds I would assume were done on an orbital. my dad gave it to our welder and said, "weld this up."
Compared to chrome-moly its slightly heavier but its still not as bad as I thought. The tube itself only weighs 8 lbs, but by the time you add the weld yokes, 1350 u-joints, and trans yoke, my guess is it weighs close to 20 lbs.
but, I can handle the increased weight for the increased strength I've got now. now if only the rearend would hold...
Old Nov 19, 2005 | 02:57 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Is this one heavier then a stock drive shaft.
Old Nov 19, 2005 | 03:05 PM
TexasLT1's Avatar
Car: '92 RS
yeah its a little heavier. Just the tube itself is 3 lbs heavier. The stainless tube weighs about 8 lbs, the stocker weighs about 5 lbs. Plus the added weight of the larger yokes and u-joints. I'd say its about 5 lbs more than stock.
Old Nov 19, 2005 | 05:30 PM
Thanks for the link.
What kind of stainless is it? Looks sweet but it could be anything from weaker then steel/chromoly to significantly stronger.
Is it still fabrication if you handed a stack of parts over to someone to put them together? Seems more like management or project supervising…
Old Nov 19, 2005 | 05:55 PM
TexasLT1's Avatar
Car: '92 RS
only part that was "handed over" was the welding, still did the assembly of the u-joints and had already pressed in the weld yokes
its 304 Stainless
Old Nov 19, 2005 | 08:31 PM
Is that where you beat it against the floor till you think it’s fully seated?
its 304 Stainless
So it should be about the same or slightly stronger then comparable mild steel, slightly heavier and a little touchier WRT to the weld joints…
Still looks sweet… I’m assuming that that’s 3” DOM, what did that piece run you? Should polish up beautifully
Old Nov 19, 2005 | 08:36 PM
TexasLT1's Avatar
Car: '92 RS
hey now, I may be from Texas, but we're not that backwoods around here.
Yes it is DOM. Since my dad deals in metal everyday we got it for $8 a foot. Got 2 10' joints of it.
Old Nov 21, 2005 | 02:54 AM
You know, it’s funny… there is stuff that I would never dare doing on someone else’s car that I would do on mine, it fits that “this seems really wrong but I can’t see how this would really screw anything up or I’ve never had a problem with it”
2x10’… that’s enough for 6 driveshafts if you cut carefully… not a bad deal, so about $90 in parts + labor… could probably sell them for about $250
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
