Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
mig welding?
Old Jul 10, 2006 | 06:24 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
mig welding?
Can you mig weld upsidedown or is the gas lighter than air afloats away leaving a poor weld?
Old Jul 10, 2006 | 07:13 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
mig welding
Yes you can mig weld upside down.
The pressure is adjustable via your regulator.
A problem you might face is if your doing this out side and its very windy, then you would have to crank your pressure up really high.
Old Jul 12, 2006 | 03:03 AM
83 Crossfire TA's Avatar
I prefer flux core, but year, just give it a little extra gas flow and you'll be fine
Old Jul 12, 2006 | 08:38 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I use flux core and mig welded upside down, while I fixed my floor pans. No problems at all. Just be carefull.
Old Jul 12, 2006 | 09:46 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yeah, it sucks whenever you get hot metal dripping on your bare arms...oh, yeah, where fire resistant full length sleeves.
Old Jul 14, 2006 | 12:03 AM
try getting one of those red hot metal goobers inside your shirt in your armpit... it's worse then getting one in a shoe...
Old Jul 14, 2006 | 06:00 PM
robsgta's Avatar
WARNING !!!
If you are welding over head wearing ear plugs will be a great idea, getting a few spatters(SLAG) dancing around inside your ears is the worst feeling, you have to immediately lean over so it runs out your ear away from your ear drum.
Old Jul 14, 2006 | 06:04 PM
mw66nova's Avatar
Engine: 7.0L
yep, been there too! i dropped a filler rod onto my neck while TIGing over head once...i still got a 4" long scar on my neck from that, though i suspect it'll go away after a while...it wasn't that bad, it just scared the **** outta me.
Old Jul 14, 2006 | 06:28 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
I had a piece of slag catch on my lip once and man did that burn, left a good little bister on my lip for about 3 days
Old Jul 14, 2006 | 09:13 PM
EvilCartman's Avatar
Car: '82 Z28
Humm some good tips, going to be welding over head tonight. Taking the night off to weld on my sub frame connectors for tomorrow's track day.
Old Jul 14, 2006 | 10:03 PM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Practice on some crap first!
I would set your machine at about 16.6 to 17 volts, wire speed 205 inches/min. (I do this stuff all day long, and have the scars to prove it)
And unless you like the smell of burning hair, put a bandana on under your helmet.
My worst weld burn took a month to heal. I got a huge chunk of molten metal caught in the folds of my canvas sleeves, right over the inside of my elbow. It burned straight through, and by the time I yanked the sleeve off, I had a pencil eraser sized, 1/8 inch deep hole in my arm.
Old Jul 14, 2006 | 11:59 PM
Car: '82 Z28
eeeeeeeewwwwwwwww lol worst I've had so far is a hot wire through the tip of my finger. Went to sweep it away, with those heavy leather gloves mind you, and it went right through.
Old Jul 15, 2006 | 01:30 AM
heh, I have a whole series of socks that have lots of little holes through the top of them from goobers that burned through the top of a shoe and into them… as long as it’s not a really bad one you usually can’t get the shoe off faster then when it stops mattering, I think I’ve gotten to the point that I don’t notice it anymore since I have a lot more holes in socks and shoes then I remember having burns.
Old Jul 28, 2006 | 06:23 PM
Pocket's Avatar
Car: 91 Trans Am
Got tons of shirts and socks that are covered in tiny holes too
Worst I had was a piece of redhot flux I was chipping off caught me on the lip
It ended up burning completely thru my lip
Moral of the story - welding gloves dont taste good and wear a full face shield when chipping hot stuff
I could fit the ink canitsters from cheap pens thru the hole no problem
Took 3 months to heal
Old Jul 28, 2006 | 11:53 PM
BRobinson's Avatar
Car: 82 Camaro
Axle/Gears: 3.08
Had a new one today. welding a doorframe into a steel enclosure (kinda like a shed) and the corner got just a tad too hot, and burned through, dropping huge chunk of molten steel onto the top of my shoe. It caught fire. So I had to stomp the hot metal into the top of my foot to keep from having a massive hole in the top of my shoe.
I'm glad it's the weekend.
Old Aug 17, 2006 | 11:56 AM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
Is mig welding better than TIG Welding? What type and size machines to you guys use. I want to get one a learn but Im a bit lost.
Looks Like Tig Welders are more expensive
Old Aug 17, 2006 | 03:45 PM
They’re different.
MIG is easier to just pick up and do, but it’s also more difficult to REALLY do correctly. TIG gives you more control of heat and filler, MIG is much cheaper and MUCH (like on the scale of 5-20x) faster depending on what you’re doing. Both can be done much better sitting at a welding table, but there are just some things that are next to impossible with a TIG that can be done easily with a MIG (ex: exhaust and subframe connectors… yea you can lay on the floor with the TIG pedal between your knees like a thighmaster and sort of get it done if you have someone else positioning or a lot of clamps… or you could just zip it up with a MIG…)
It’s really, REALLY nice to have a TIG welder, but even with the best TIG I still wouldn’t want to be caught dead on most stuff that I weld without a MIG.
Old Aug 22, 2006 | 06:56 AM
robsgta's Avatar
Tig lays down the cleanest welds and requires technique and skill. (there are Miller tig welders that you can adjust the amperage and gas flow and just start welding at a set amperage with out the use of a pedal just the **** on the torch ) Tig = cleaner welds, sheet metal, thin tubing, precision welds, you can also lay thick beads with this as well.
Mig = easy to use, makes filling holes or gaps a breeze, subframes,mufflers, joining of heavy metal, axle brackets etc etc.
Old Aug 22, 2006 | 05:57 PM
BRobinson's Avatar
Car: 82 Camaro
Axle/Gears: 3.08
There are thumb/finger switches for TIG, so you don't have to position youself weird while doing anything other than waist level stuff.
Old Aug 30, 2006 | 02:40 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i went through that like 2 years ago. i bought a diy book that has the different types of welding and what you can do. i think for the car hobbie DIYer with a budget the mig is the way to go. so i went to the welding store and got a hobart 180(mig). the salesman actualy helped me too. i was going to buy the lincoln 175 for extra money but he said the extras it had i wouldnt use and i think he was right. now im glad i went the way i did i can weld small to pretty big with this and im starting to get pretty good at it. i dont use it very much but when you need, it you need it.
Old Sep 3, 2006 | 02:47 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Try swallowing slag! You'll feel it all the way down to your stomach. Cutting off a muffler clamp. The molten piece fell, hit the hoist, splattered, and me, the dumb *** with his mouth open, swallowed it. NOT a pleasant feeling, I can assure you. My advice......keep your freegin mouth closed!
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
LC2 TECH
Oct 13, 2015 11:53 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
