Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Battery box
Old Aug 20, 2006 | 06:35 AM
Dan W's Avatar
Battery box
Thought I'd post a picture of the battery box I made over the winter. The one I bought from summit didnt fit in the hole so I decided to break out the welder and some scrap and build one. I'm happy with the result... the disconnect switch lines up between the bulbs in the tail light so I'll get a spare tail light for the track that I'll drill a hole through for the required "push off handle".
Old Aug 20, 2006 | 06:39 AM
Dan W's Avatar
I did a little work in the front while I was at it... boxing in the front corners was easy and I think it looks really good.
Old Aug 20, 2006 | 11:02 AM
Stevo's Avatar
Car: Pair of 92 Z28s
cool stuff, now make me a box
Old Aug 21, 2006 | 02:24 AM
83 Crossfire TA's Avatar
Not bad… here is the one built for my brother’s car:
This one ended up a lot smaller then normal since he decided to run a lawnmower battery instead of a real car battery.
Here it is mounted in the trunk and you can see what he did with the power switch, which I think is slick, it’s mounted right behind the plate with a hole drilled all the way through one of the mounting holes. On the street he just unscrews the thing and there are no extra holes that shouldn’t be there, at the track he fishes the “push off” button/rod through the hole and threads it into the piece on the end of the switch lever:
Johnoooooo
Sep 22, 2015 08:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
