Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
What type of Welder
Old Jul 26, 2008 | 05:25 PM
  #101
firstfirebird's Avatar
Re: What type of Welder
Thay only had 10k ohm and 5k ohm potentiometers when I went, and used the 10. I will gladly take a pic of the inside of the machine for you , junk, after all I've been called the "king of pics" in the past haha.
Old Aug 20, 2008 | 03:17 PM
  #102
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Update:
The surpluscenter.com 12V contactor has been working great. The contacts show no wear and the heat load seems fine. I will try to post a few pics of the contactor and wiring by the end of the week.
Firstfirebird,
If you get a chance for some pics, try to take one of the following:
1) pic of wires attaching to alum. plates and where they connect to.
2) pic of wires going from alum. plates to printed circuit board & wire feed motor
3) pic of where the ground clamp wire goes to
4) pic of where the wire feed small wire from the gun goes to (probably the PCB)
The 12V contactor link
(http://www.surpluscenter.com/item.as...-1722&catname=)
Old Aug 21, 2008 | 11:29 PM
  #103
Sorry, until I saw your reply, I almost forgot.
The HF welder bit the dust, finally. It served me for 5yrs, making three complete turbo kits (one running 13flat in a V6 Corsica), repaing a lawnmower deck with strips of mild steel from Home Depot, making a new SS grate for my BBQ, multiple minor repairs, making a seat for my childrens' go-ped, putting a new exhaust on my truck, all-in-all I would say many spools of wire went through this $129 machine, and was worth every penny.
The problems started with a burnt trace on the board, and the fuse blew at the same time. I jumped the trace with wire, tested, and another trace burned. I followed both traces to a rectifier. Went to Radio Shack and replaced the rectifier with the correct replacement, and now the trace leading from the fuse burned (along with another fuse).
At this point, I gave up on it. We had a Craftsman gassed MIG sitting at the back of our shop, so I decided to take a look at at. We couldn't locate the parts to make the repairs necessary to the Sears machine, so the HF machine was hacked, thread with a die and the Craftsman is now a HF-tipped welder I can't believe how much more wire speed control I now have (no movement to stupid-fast), and the arc is certainly more consistant. The Craftsman has a transformer and regulator - whereas the HF had only the small circuit board and transformer. The HF had a small 9-12v DC brushed motor for the wire speed (found in a slot-track car), and the Craftsman has a worm-gear driven wire speed, and the motor is closer to the size of a soda can.
Here's the pics I took thus far, more upon request (HF machine)...
The circuit board was driven directly off the leads to the coil/transformer. It probably could have been repaired using a 120v to 1amp adapter from the infamous Radio Shack, but I figured that the welder served it's purpose and now can't wait to get some argon in the Craftsman just the consistancy of the spark is nice, and can't wait to see what happens with gas. Also noticed the nice fan mounted in-house from Sears.
Old Aug 25, 2008 | 02:24 PM
  #104
junkcltr's Avatar
Engine: 3xx ci tubo
Interesting. That HF machine doesn't DC rectify the AC transformer output. In order to use the contactor mod. you need a DC output (alum. plates with 4 diodes).
Since the HF doesn't have a DC and uses AC instead, that is why it doesn't weld as constant as a true DC- flux core machine.
That sucks that the PCB broke. It is great that you used the good parts on the Sears machine. That Sears box will last just about forever. You might be able to turn the old HF transformer into a batter changer depending on the output voltage.
Old Aug 25, 2008 | 02:42 PM
  #105
The HF box states that it's 60-80v output.
Is that a rectifier on the left side of the coil in the pic (small black round with 4 wires)?
Yeah, I'm curious to see about the gas on the Sears machine, the HF tip has smaller orifices and the ID of the tube is a little smaller. If worse comes to worse, I still have a flux core welder that throws no slag in comparison to the HF.
I'm interested in doing the contactor mod on the Sears machine if possible. I'll post some pics of that machine if needed.
Old Aug 25, 2008 | 05:09 PM
  #106
junkcltr's Avatar
Engine: 3xx ci tubo
That voltage is too high for making a battery charger. I would say make an AC arc welder out of it, but the 115V arc welders just don't put out enough juice to be usable.
Yes, that 4-pin device with "2W04" is a bridge rectifier. It is a 2 amp, 400 volt rectifier. It turns the AC from the transformer to varying DC. The other reistors and FET create a stable/constant DC voltage for the wire feed motor.
There is more slag with the HF unit because it is AC and does only DC- half the time. The other half the time is DC+ which is not ideal for flux-core wire.
I am surprised the HF unit has a diffuser that you can use with gas. The Campbell Hausfeld unit I have uses Tweco components. Your HF is probably the same.
That Sears machine probably already has a contactor in it. Did you test it to see if the wire is always live?
Old Aug 25, 2008 | 11:41 PM
  #107
I'm fimiliar with the rectifier you mentioned, that's the one I replaced thinking that was the problem in the PCB.
This is what I was inquiring about...
I believe the HF has the difuser bacuse they use the same parts on the gas and flux machines they offer to keep things simple. My concern is that the HF gas machine has a small (aprox 1/4") tube to supply gas whereas the Sears is at least 3/8". The Sears has a nice tip lead with the ground wrapped solid around the wire feed and gas hose (similar to a coaxial cable, not parallel like the HF). The HF tip has a lot smaller ID, and I was able to die the outside of the HF tip to thread inside the Sears tube.
Yes, the wire is always live. It gets annoying when doing multiple welds, or in precarious positions, it's easy to accidently touch the subject with the wire. How else would I notice the difference in the quality of the spark Actually, don't know if I ever mentioned that the Sears machine was not operable when I got it.
Old Aug 26, 2008 | 09:14 AM
  #108
junkcltr's Avatar
Engine: 3xx ci tubo
That 4 terminal device on the main transformer is a thermal switch. When the transformer gets too hot the switch will open and turn off the welder. I picked up a new Clarke 130EN that was non-operational for cheap. It turns out that one connection to the main transformer thermal switch was bad so the machine would not turn on.
I was guessing that the Sears box had a contactor in it, but it doesn't from what you wrote. Does it have two big aluminum plates that the wires from the main transformer connect to? I am guessing it does because you said it welds much smoother with less spatter.
EDIT: I welded in some O2 sensor bungs on the latest project this weekend...........upside down under a truck. The switched on/off wire voltage made all the difference in the world. I don't think I would have been able to cleanly weld the O2 bungs without the contactor in the machine because the wire would burn off when the wire contacted the steel before.
Old Aug 26, 2008 | 09:26 AM
  #109
junkcltr's Avatar
Engine: 3xx ci tubo
The HF machine in the picture doesn't have a main transformer DC rectifier for welding. You are actually welding using AC with that machine. Since flux-core wire prefers DCEN (DC-) that is why it spatters. The DC+ portion of the AC wave will make it spatter more.
The fix for it would be to buy a couple scrap pieces of aluminum and 4 diodes (Ebay) for about $10 - $30.
Old Feb 11, 2012 | 09:35 AM
  #110
Thanks junk and Mark for the kind words back then. Finally got a TIG a couple years ago, and tried this yesterday. This was the 3rd attempt, think they will look better with more practise.
Old Feb 20, 2012 | 11:29 AM
  #111
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I've got a couple questions for you guys about the HF flux-core welder. Yes, I know, MIG and such is preferred, but I'm going to be welding outside, and need the flux-cored wire, plus even MIG is out of my price range (and I already have the HF welder that has barely been taken out of the box and hasn't been plugged in yet).
First, I bought my unit within the last couple years (early 2011, I think), and it seems that HF at least provided my unit with a cooling fan. At least it's in the internal pics and the internal wiring schematic in the manual, anyways. I haven't opened it yet to find out if it's true or not since it's kind of buried on the porch at the moment (enclosed back porch).
I'd like to get the welder upgraded to make it work as it should (wire hot with trigger, DC- output, etc), but I need some instruction on doing so. I already have a couple of spare alternator rectifier bridges if those can be used (diode assemblies from a couple CS130 kits I have), and can probably source some heat sink plate and can easily get a contactor, but need guidance on how to hook it up. Wiring diagrams would be preferred...
Although, I think this may all be in vain as I don't know if or when I'm going to have a useable 20-25A circuit to plug it into (blasted 200 year old house!). The welder hasn't even been fully assembled yet (handle and such), much less plugged into an outlet and heated up. I have scrap metal to practice on before I go to start plugging rust holes...
Old Feb 24, 2012 | 12:44 AM
  #112
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
funny, first time I get on in a few months, I came to look for a thread on welders, and one is bumped from '08!
what do you guy's think of a rig like this?
http://www.lowes.com/pd_364476-1703-...der&facetInfo=
I wouldn't pay that much for it, there are other places cheaper online but do you guys think it's a good unit?
Old Feb 29, 2012 | 04:32 AM
  #113
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Maverick, if you're dead set on doing that, check out weldingweb.com
They have a section dedicated to harbor freight stuff, and there's lots of information on how to mod them there.
You'll be much happier with MIG though... It's a lot easier to see what you're doing, as a beginner. Much more forgiving on thin metals too, and there's no reason you can't use MIG outside. Just set up a wind block if there's too much breeze.
As for that Lincoln TIG... Personally, I never cared for the Lincoln TIG welders, I prefer the Miller's arc. But whether that would be a good machine or not completely depends on what you intend to weld?
That particular model is a squarewave AC machine, so it gives you the capability to weld aluminum. But if you're serious about welding, an advanced squarewave machine will let you "tune" the AC balance, and that makes a huge difference in the weld.
The Miller Diversion series will be comparable to that one, look at them too. I'd also recommend looking at the welders HTP has to offer, they make some nice machines at a great price.
Old Feb 29, 2012 | 04:55 PM
  #114
Engine: 2.7L V6
Axle/Gears: 4.41
I'll check out that link...
Reasons I'm sticking with the HF welder are many:
1. I'm cheap. I could have gone worse and borrowed one of my 2 neighbors' oxy torches, but I wanted a welder for other things as well (too bad the lawnmower deck got even worse and had to be tossed). I can't afford a MIG, especially to have it just sit around waiting for the power issues to get sorted out (probably going to have to hire an electrician to get 20A outside ). Used part of a tax refund to pay for it in the first place.
2. It gets windy around here a good portion of the time.
3. I'm familiar with flux welding (had a class in HS where we used stick welders). Just not wire welding. If I had been in my second year of that class, I would have learned MIG...
I'm probably going to end up selling it when all is said and done anyways, probably to my one neighbor (or may trade it for a car).
Old Mar 1, 2012 | 04:21 AM
  #115
Actually, oxyfuel isn't a bad way to go, once you get the feel for it. It'll give you far more capability than the harbor freight welder will. That's what "old school" bodywork is still done with. Give it a try man, if your neighbor will let you try it
Old Mar 1, 2012 | 06:37 PM
  #116
Engine: 2.7L V6
Axle/Gears: 4.41
Problem with that is that one is a trucker that's almost never home and the guy on the other side is a complete wack-job. I've done some oxy welding before but not on anything thinner than 1/8" thick (or thereabouts). I need to talk to the trucker guy and see what, if anything, I can manage. Good thing it's still just a bit too cold out to work ATM...
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Briandrex
Oct 5, 2015 06:20 AM
bjpotter
Oct 4, 2015 07:48 PM
