Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Glue Gun
Old Feb 27, 2007 | 04:52 PM
Camaro-please?'s Avatar
Car: 88 Camaro Sport Coupe
Engine: 305 TBI
Glue Gun
Ive used it so much in the interior, its great
Old Feb 27, 2007 | 06:32 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Umm... the whole point of this thread was to make that statement? Or do you have a question somewhere deep within that subliminal message?
Old Feb 27, 2007 | 07:12 PM
Engine: 305 TBI
no way , just throwing that out there
Old Feb 27, 2007 | 08:16 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Noted.
Old Feb 28, 2007 | 10:57 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Any particular examples you'd like to share with the class?
Old Mar 1, 2007 | 10:16 AM
Engine: 305 TBI
Well mostly for cloth, just glue gun it,....but the t top brace that you clue the cloth on it is reallyeasy for it to come off
Old Mar 1, 2007 | 02:01 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
+1 for the hot melt glue gun. I use them alot on speaker box fabrication; they make a better sealer than silicon and hold carpet on better than the spray glue.
Old Mar 2, 2007 | 11:49 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
How does it hold up long term?? Heat, cold, moisture, vibration, etc.
Old Mar 2, 2007 | 12:47 PM
Engine: 305 TBI
I dont know will find out
Old Mar 6, 2007 | 02:55 AM
83 Crossfire TA's Avatar
Wood glue and brads… sometimes I’ll use polyurethane glue, if the joint doesn’t fit air tight you didn’t cut it right, and I’ve built boxes that people thought looked so cool that they were just coated with tung oil and left like that, basically bare MDF.
Glue gun… I’ve used it for joints that I wanted to take apart later, but never used one for anything permanent. I’d be worried that it would eventually fall apart on it’s own when used in a car interior.
Old Mar 20, 2007 | 07:16 PM
Engine: 305 TBI
Re: Glue Gun
Yea that was a temporary solution what should i do now i lost the clips its hanging on but sort of sagging, i was thinking of like velcro.
Old Mar 20, 2007 | 07:28 PM
Re: Glue Gun
I use the brads, and wood glue the seams before I put them together, the hot glue goes inside to form an airtight seal. You can use more wood glue for this but it's way faster to just lay a line down with a hot melt glue gun. Hot glue won't bond to wood, but it will fill seams. For that matter brads alone won't hold the wood together after time they'll pull loose, always use quality wood glue between every joint.
Old Mar 21, 2007 | 09:14 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Re: Glue Gun
I just gone done using a hot glue gun to attach black vinyl to my sail panels. Its not the best on the corners, but it worked pretty good, I think once they are screwed in the car, they'll be ok. I cant wait to use the glue gun again!!
Old Mar 21, 2007 | 10:43 PM
HCR13's Avatar
Car: 1987 Trans Am
Re: Glue Gun
I agree, I used a hot glue gun, today installing my black door panels. Came in real handy!
Old Apr 10, 2007 | 12:00 AM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
Re: Glue Gun
I spent $2.10 at a dollar store. Got a Glue Gun and 50 glue sticks. overall the gun is junk but ive fixed many more then 2 dollars worth of things with it. They work great for repairing damaged interior bolt holes
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
Fox118
Sep 12, 2015 09:29 PM
86IROC112
Sep 11, 2015 04:04 PM
IROCZDAVE (88-L98)
Sep 6, 2015 06:23 AM
mav75
Aug 31, 2015 12:16 AM
