Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
over flow catch can????
Old Mar 3, 2007 | 11:26 PM
85blkburd's Avatar
Car: 85 firebird
Engine: 305 ci. 4 bbl.
Axle/Gears: one wheel peel
2007 NHRA rule book says all cars MUST have a radiator overflow catch can. My car does not have one!!! YET!! so I need to have one by april 7th. empty beer can??? I want some thing cool any ideas?? any body ever heard of ET Raceway Lyons Indiana??? cool track if your ever down this way check it out burn out!!!!!
Old Mar 3, 2007 | 11:33 PM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
some will let you get away with a beer can or pop bottle. Just use a piece of hose and tape it to a bottle. too easy.
Old Mar 4, 2007 | 01:14 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Must hold a minimum of 1 pint.
I use a rad overflow bottle from an old Volvo 240. Nice round bottle with mounting bracket and has a bottom feed. I guess it's more of a surge tank but still does the job. Rad is always full and I just keep a minimum of fluid in the overflow.
Old Mar 4, 2007 | 07:59 AM
85blkburd's Avatar
Car: 85 firebird
i know about tape!!!! seen that before, and that would be too easy!!!! trying to come up with something a little more creative than that. i just said empty beer can in the original post because i have a few laying around!!! haven't seen many volvos around here either, but some thing like that i'll look for. don't want my car to look like i built it with trash i picked up on the side of the highway on the way to the track!!!!!
Old Mar 4, 2007 | 09:47 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Since you don't want to fabricate something, just buy one of these.
http://www.jegs.com/webapp/wcs/store...56127_-1_10127
Old Apr 23, 2009 | 10:24 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Re: over flow catch can????
Old thread, I know.
I must be stupid or something, but I installed a catch can with a drain valve, inlet, and a vent port in my Camaro. The goal is to simply replace the ugly stock overflow tank. However, it isn't recirculating, any idea why?
Old Apr 27, 2009 | 01:25 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
A catch can is not an overflow, it is simply there to catch what comes out so it won't drip on the track. an overflow will have an inlet at the bottom, when the pressure in the radiator drops and the cap opens back up it can siphon back into the radiator; a catch can has no provision for this because the inlet is at top. The valve at the bottom is so you can drain it off and dump it back in your radiator if needed.
Old Apr 27, 2009 | 05:00 AM
Awesome-X's Avatar
Car: 87 Camaro
Hey thats cool I go to ET all the time lol maybe i'll see your car around sometime
Old Apr 28, 2009 | 05:55 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
plas check out canton racin they have alum. replacements for our overflows look sweet
Old Apr 29, 2009 | 01:09 PM
fastlane350's Avatar
Car: 1987 iroc-z
Engine: 350 TPI.. stock :(
A friend of mine is a med student, he has emtpy IV bag secured to his inner fender for that. as long as its secured well they pretty much go for whatever...
Old Apr 30, 2009 | 09:33 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Ended up buying a recirculating catch can off of summit, some red 1 liter can thing. Works well. Thanks for the replies.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
dusterbd
Sep 29, 2015 08:40 AM
