Coolant and Windshield Tanks Delete/Relocate
I finally got sick and tired of those ugly yellow tanks that take up more than half of the engine bay, so last saturday i decided to get rid of them. I took off the old tanks and relocated the charcol canister into the front bumper. I used the exsisting mounts on the canister and just drilled into the bumper. I then used a duel tank out of a 89 lincoln town car (yeah i know a ford product in a gm, it kills me!) and placed it where the charcol canisters spot. i then simply extrended the hoses and then you have it.
Tell me what think, Comments?!
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Coolant and Windshield Tanks Delete/Relocate
That looks pretty good with them out of the way.
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
NICE ! I knew about the Explorer tank but it looks like there's another option available too.
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
when you use a coolant/washer tank is it a PITA to install or does it just plop in?
If you are talking about the (for example) explorer one shown above, it just sits there, only problem was there is a charcoal canister in the way that must be removed or relocated. The only part that I could think of that may be a PITA for some people was soldering the two lines to the washer's pump so the pump can get power. Other then that mine just sits there with some black zip ties to make sure it doesnt move.
-Russ
-Russ
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Isnt the washer fluid tank restricting the air flow to the intake filter???
I did away with the charcoal canister completly in my car.
The whole unit is held in place with the original Ford 10mm self tapping screws into the Radiator Core support on my Formula.
Also, I cut the plug and a couple inches of wiring from the Exlpoder, so all I had to do was splice the power and ground wires from my factory harness into the wires for the Ford pump.
Thats the same thing I did, I left a bit of extra wire from the plug but i soldered them onto to original lines. Just wanted to make sure they wouldn't move. I like it better now but I think Im going to get a smaller one and put it under the hood latch cover. I saw someone else on the boards who did it and right now I only have my alarm under there.
-Russ
-Russ
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Mine are under the batt tray & under the plastic cover between the headlamps at the top of the rad support.
yeah i will say that the filter is not in the best position but i did run some house 4 in ducting from each fog light, in the front bumper, to a tee and then hosed that right to the filter running inside the passenger front fender. hopfully it will have just as much airflow as before.
Car: Used to drive a camaro
Here's the way I did it (almost). I took the red resevoir out and put in another one of the white universal ones for coolant so they are both identical now.
https://www.thirdgen.org/forums/auto...her-fluid.html
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I got rid of the washer fluid, and as for the coolant, I just bought one of those summit universal catch cans for a wopping $10 I think, and installed it in front of the core support. I still need to paint it flat balck, but you get the idea. (ignore the lambo door hinges I took those off)
Car: 1987 Iroc-z
Transmission: Modified T-5 World class
Axle/Gears: 9 bolt borg-warner 3.45
That's a really good idea. Wish I had thought of it before I puller the two tanks last week and paionted them both wite to hide that nasty yellowing effect. Maybe this is a project for a later date though.
Car: 87 GTA
The intake is just getting hot, underhood air anyways, so I wouldn't worry about that. I'd suggest building an insulated wall though, so the filter only gets outside cooler air. Like, through the fender gaps, or cut a hole though the tray under it, for the filter to hang out under there etc.
Car: 1987 Iroc-z
Okay, I just got back from the wreckers with a mercury Marquis washer tank (same as in the lincoln and ford crown vic)
Do you have to use the ford washer pump? I noticed when I pulled the tank the washer fluid flowed right past the pump and through the hose. I'm thinking that I can just attach the ford hose running from the pump into the GM pump and it should work shouldn't it?
Car: 91 Camaro RS
Engine: 305 TBI LO3
if you're going to go through the trouble, splurge on some body work and get them fender walls smoothed out and painted.
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
did GM not make a combo tank???? if I put a ford part in my Camaro it might throw it up LOL
AC- is that tray on your car stock? it looks great, great for hold tool I bet. also, whats that round thing on the other side of the tray opposite the coolant tank??
C.M.Jones, the red round "thing" was a summit overflow bottle that I ended up taking out to replace it with another coolant tank just like the white universal one on the pass side. SO, now I have 2 of the exact same tanks in the front, 1 for coolant and 1 for windshield squirt. The tray was stock, I just cout out the air filter holders and fabbe'd up the tank holders to go in place.
interesting, I want a Tray like that. sombody?
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
yes GM did make a combo tank. My father had one in his GMC Sonoma. (then again he also had a ford ranger so i could be getting them confused)
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Im running a 4th gen overflow, and a 4th gen washer tank. Both of these options are quite a bit more work. However I dont have a spot for an explorer part...or I would have done that instead.
The overflow requires a pretty decent sized hole cut in the battery tray. And the washer bottle requires some inginuity to install up front.
J.
J.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
You dont have to cut your battery tray to install the 4th gen coolant tank.I mounted mine underneath using two bolts to hold it in place.There are four threaded bungs welded to the batt tray.One is used by the batt hold down bolt.I used that & the one opposite that for the 4th gen install.The washer tank is mounted angainst the rad support.Just under the plastic cover between the bumper & radiator.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I already mounted a 4th gen washer tank in the nose, and I really want to get rid of the coolant overflow tank on the wheel well. I was thinking of dointg the 4th gen coolant tank as well. The only thing was getting aroung to cutting the battery tray, but if I don't have to cut it. I'm doing what you did. Oh, how/where is the spout sticking up.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yes the batt hold down doubles to hold the 4th gen coolant/batt tray in place.The filler next squeezes thru the space between the batt & fender.I had to heat the neck with a heat gun to clear both the batt/fender.I did this by stuffing an old shirt in the neck to keep it from collapsing.Once it was soft i bent it slightly towards the battery.Just enough to clear the fender.Heres a few pics.However this is an old mod & i posted on this wayyyyy back in 06.
here you can see both bolts
here's the batt hold down bolt
bottom view
filler neck
bottom view
filler neck
Sweet, thanks for digging up those pics. Looks like I'm hitting the junk yard.
Car: 1990 Nissan 240SX
Engine: GMPP Gen0 350 small block
Transmission: WC T5
Axle/Gears: Nissan R200 3.133, Tomei 2-way
Bump with a quick question. I used one of the Anco universal washer reservoir/pump and mounted it in the trunk because I have no space up front.
http://store.summitracing.com/partde...5&autoview=sku
It works great, but the only problem is when I brake moderately, fluid dribble out of the windshield sprayers just enough to leave a mess on the hood.
Any suggestions? My mechanic recommended using a relief valve so that pressure must be high to pass through to the sprayer.
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
i just got a chrome one thats a combination, its about the size of a battery. I deleted the evap canister and put it there.
I found some old pics I took when I was doing my setup. My mod can be done with some sheet metal, (2) universal tanks from Napa (8 bux a piece) and the stock TPI dual air filter filler panel.
https://www.thirdgen.org/forums/atta...icture-266.jpg
Car: 87 GTA
Is that a 4th gen tank? Overflow container or washer fluid container?
It looks that was a Camaro in your pics, judging by the battery on the passenger side. But I see no reason I couldn't do that to my driver's side battery too.
Car: 86 Trans AM
thats the 4th gen coolant overflow/battery tray... You might be able to fit it over on the driver's side, but its gonna be a chore.
My 87 TA had the battery on the driver's side, but my 86 had it on the passenger side. So your best bet is to just put the battery on the passenger side, regardless of what it is from the factory. If your charcoal canister is on the passenger side, just re-locate it to the drivers... Piece of cake.
J.
J.
Car: 87 GTA
Not a piece of cake. The factory air filter housing is over there & takes up even more room than the charcoal cannister.
What's below the battery on the driver's side that would make this so hard to do?
Car: 86 Trans AM
But its possible...I would hate for you to cut that hole in your tray and find out it doesnt work though. I had the 4th gen bottle mounted in my 87, however I couldnt bring myself to cut into the 86, so Im searching alternative options.
S10Wildside: did you have any issues with bolting the tray down? The holes that I had to make didnt last long. Especially the hold down bolt. I was gonig to weld a nut under it this time around...
Car: '89 IROC-Z
Engine: 355
not the best pic but you can see the battery sized chrome coolant/windshield tank where the evap canister used to be.
i used the 4th gen washer too even tho i hated to put weight even closer to the front end. i was planning on putting each of them behind the fender wells close to the fire wall but this was a lot easier
I'm working with a 91 Trans Am convertible. The battery was originally on the driver side, but now the PCM and Corvette Throttle Actuator Control (TAC) module are going into the original battery location. The battery is moving to where the charcoal canister and air filter were. The charcoal canister is moving to the top of the LS1 gas tank, which is the stock location for the LS1 charcoal canister. I'm building a brand new harness for everything, so the location of components really doesn't matter at this point.
aluminum, bottle, canton, combination, combo, container, coolant, fabricated, fluid, overflow, radiator, rv1890, tank, washer, windshield
