Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Ashtray Switch panel, Lots of pics and diagrams
Old Aug 11, 2007 | 10:22 PM
Pocket's Avatar
Car: 91 Trans Am
*Note* This is for the 85-92 FIREBIRD console
82-84 Firebird may or may not fit, I dont have any consoles to test this on
Will NOT fit camaros
Ok This is what you start with
This is what you need
Installed
With switches, please note that the left most area is taken up by the underside gear mechanism so no switchs can be mounted here
Closed and switches cleared
Bolt that holds it in place, be careful to drill it in between the switches so you dont put the screw right into a switch terminal
View of the console and inlet for the wires
CAD of the piece needed
Dimensions, I used a section of composite handrailing left over from a carpentry job
There ya go!
Old Aug 11, 2007 | 11:18 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Re: Ashtray Switch panel, Lots of pics and diagrams
Old Aug 12, 2007 | 03:26 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
props! whats the extra switches going to be used for?
very, very clean mod.
Old Aug 12, 2007 | 07:54 AM
Pocket's Avatar
Car: 91 Trans Am
Blue-Coolant Fan
Red-Heated O2 Power
Yellow-Interior LEDs
Old Aug 12, 2007 | 02:11 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Reminds me of my old setup before I went to a 4th gen console.
Attached Thumbnails Ashtray Switch panel, Lots of pics and diagrams-img_1722.jpg
Old Aug 13, 2007 | 09:47 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Hmm, very slick, thanks for the info!
Just a tip though, i'd wire the heated O2 to ign power. I've heard NOT running power to it while the car is running ruins it very quickly. Same with the coolant fan, use a thermal switch and you don't need a toggle switch. Don't get me wrong, I love having more buttons and switches in my car but only when needed
I'd use it for my line lock, maybe a coolant fan override.....
Old Aug 13, 2007 | 09:51 AM
i_love_thirdgen's Avatar
Car: 92 camaro,99 s10
...and to finish Sonix reply... a 125 shot
Old Aug 13, 2007 | 04:03 PM
Pocket's Avatar
Car: 91 Trans Am
I have ZERO splices on my cars electrical system
I use the factory junction block near the battery whenever I draw power to a new thing
This block is 12v HOT at all times
I hit the O2 switch once I crank the car and when I shut it off
As for my coolant fan, Ive been running a switch since I burned up 2 fan sensors and almost overheated a few times
Little over 2 years, I only changed the plate because the first set of switches melted
Old Aug 13, 2007 | 04:37 PM
Car: 86 T/A
Engine: HSR 355
Why bother with a switch then- wire it to the ignition like it was said and never worry about it.
Old Aug 13, 2007 | 11:01 PM
Pocket's Avatar
Car: 91 Trans Am
Cause Im being hardheaded
Old Aug 14, 2007 | 12:10 AM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
good idea looks nice
Old Aug 16, 2007 | 11:39 AM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
I like it. I'm trying to figure out where to put a switch panel, and I think I may have found it!
Old Aug 16, 2007 | 07:27 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I agree with ya on the o2. Deff. run it to Ign.
Id say run the Fan thru a thermal switch like said also but Its nice to have a switch to override and keep it on for when the car is parked in the pits cooling off in between runs.,
Old Aug 17, 2007 | 07:18 PM
84bandit's Avatar
i built one for my car 84 trans am, the lid doesn't shut, but other than that it's great. used the stockash tray, cut out the bottom, leaving just the rim and about 1/8 inch of material sticking down, the used 1/16 in sheet and tack welds on the corners,
Attached Thumbnails Ashtray Switch panel, Lots of pics and diagrams-trans-am-025.jpg
Old Aug 18, 2007 | 06:10 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
thats what relays are for
Old Oct 8, 2007 | 09:21 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
pocket - how long that hold up? I had something similar in my camaro - 4 switches - the auto linkage went right by my wires - long story short, wires broke free...guy I bought the car from had a power wire there I had reused, assumed it was fuse - stupid assumption ..almost got messy for my baby. Have any issues w/clearance?
Old Oct 9, 2007 | 02:30 PM
Pocket's Avatar
Car: 91 Trans Am
No issues with the wires hitting the shifter parts, I zip tied them out of the way
Holding up fine ever since I posted this
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Aug 14, 2015 08:25 PM
