Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
ford 8.8 and four link set up?
Old Oct 6, 2007 | 12:48 PM
proxemics's Avatar
Car: 87 Z28
Engine: 383
Transmission: th350
Axle/Gears: ford 8.8
I found a nice 8.8 ford rear that came out of a 95 mustang and I'm thinking about using it but insted of fabbing the torque arm can I use a four link set up insted without changing any thing else ?
Old Oct 7, 2007 | 10:31 AM
Vader's Avatar
Re: ford 8.8 and four link set up?
I don't have any advice for adapting that axle, but am wondering why anyone would select that design for conversion. It's not a 9-inch. A 8½" ten-bolt is likely a superior axle, and you'd find a lot more gear choices for it.
Old Oct 7, 2007 | 11:31 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I beg the differ. You can make a 8.8 really strong. Plus there are allot of options for it.
Old Oct 8, 2007 | 10:29 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
Yeah, the 8.8 is basically a 12 bolt chevy in ford clothing. Same bearing kit, as a matter of fact.
Just throwing this out there, but I have seen this kit or a fab where you solidly tie the lower control arm to the differential housing, and use the factory lower link mounts. Along with the panhard bar, it's a 3 link system, that doesn't require a torque arm or chassis fabrication.
Old Oct 8, 2007 | 04:25 PM
Pocket's Avatar
Car: 91 Trans Am
If you fuse the LCA point on the rear then your making a sort of Ladder bars
The arms would need severe strengthening as well as the chassis reinforced at the pivot points
4 link is superior
Old Oct 8, 2007 | 08:30 PM
jwscab's Avatar
Engine: Many
obviously, 4 link is much more adjustable. It also requires much more fabrication.
I will agree that the factory arms are somewhat weak. However as a point of reference, in the normal f-body suspension, these two arms are the only load bearing links on the car for forward motion.
what I recommended is in fact a type of ladder bar, but it gets you down the road for the least cost and fabrication.
Old Oct 9, 2007 | 02:36 PM
Pocket's Avatar
Car: 91 Trans Am
You still have to strengthen the chassis mounting points a good bit
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
