Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Anyone here coat their own bolts?
Old Aug 21, 2007 | 12:32 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Hey, I was wondering what you guys do to coat all of your bolts (if you do so). I've thought about coating them with a thin solution of POR-15. Also have thought about blueing them (like gunsmiths do to guns) but I can't find any information on blueing. Any suggestions?
Old Aug 21, 2007 | 12:35 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: Anyone here coat their own bolts?
POR-15 is crap it will come off
Old Aug 21, 2007 | 12:37 PM
ntomsheck's Avatar
Car: 1989 GTA
Of bolts? I could see that happening. But otherwise it's great. I have it coating my two footweels right now (for driver and pass). I struck it with a hammer multiple times and it didn't even chip (until I struck it hard, then it just chipped right where it hit)
Old Aug 21, 2007 | 01:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Did you look at Eastwood? I think they have a few setups for nickel plating or chrome plating etc.
Along with a shaker to clean up the bolts first.
Old Aug 21, 2007 | 01:30 PM
bnoble's Avatar
Car: '91 Firebird Formula
Engine: 383 w/ BW S400 turbo
Transmission: TH400
Axle/Gears: QP 9", 35 spline, spool, 3.15:1
You might also want to try Caswell Plating. They sell a Black Oxide kit that may be what you're looking for
Old Aug 21, 2007 | 03:44 PM
ntomsheck's Avatar
Car: 1989 GTA
Hmm, thank you both. I never saw that at eastwood, but I found it as soon as I went on haha.
Old Aug 21, 2007 | 06:54 PM
Stephen's Avatar
Car: 87 GTA
**edit**
Old Aug 21, 2007 | 08:33 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Originally Posted by Stephen
Personally, I won't deal with Caswell, ever again.
They charged more for shipping, than the 2 items even cost, and there was no way to find out the shipping cost, until after te order was complete.
In essence, my $10 items cost $25, in the end!
What did you order. I order a ton of stuff form Techline coatings and From caswell before.
You have to consider hazmat fees are ALOT more then what a product cost.
I ordered a small 8oz Bottle of DLF to coat my bearing and there was a $25 hasmat Fee on top of the $12 shipping fee.
Old Aug 21, 2007 | 09:21 PM
Stephen's Avatar
Car: 87 GTA
MY BAD!!!!!!!!!!!
I just dug out my receipts, and Caswell was cool. It was something else, from somewhere else, that I order.
Old Aug 21, 2007 | 09:26 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Might want to edit your post then, word of mouth can be brutal- especially if it isn't true and someone misses your correction.
Old Aug 21, 2007 | 09:36 PM
Stephen's Avatar
Car: 87 GTA
Good point...I deleted all the text.
Old Aug 22, 2007 | 02:12 AM
Vader's Avatar
A Dacromet / polyester coating works well for corrosion protection and to prevent seizing. You can do the actual coating process at room temperature, but the coated parts need to be force ventilated to flash off the solvents, then be baked at about 400ºF to cure and set the coating. Be careful not to exceed the coating cure temperature to avoid the risk of hydrogen embrittlement.
Old Aug 22, 2007 | 07:03 AM
ntomsheck's Avatar
Car: 1989 GTA
Quite interesting, I shall look into that.
So no one has any information on hot blueing?
Old Aug 22, 2007 | 10:21 AM
fireeagle43's Avatar
I don't coat them with por15 or blue them, but I do powdercoat alot of my nuts and bolts plus smaller brackets, until I get a dedicated oven to do bigger items. Seems to do an excellent job holding up to alot.
Plus, home powdercoating systems are cheap now from places like Eastwood, Harbor Frieght, and a few that powdercoating is all they do. I paid less than $200 for mine and it came with 4 different powders to get started with.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TheExaminer
Sep 6, 2015 11:40 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
