hood scoop
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
hood scoop
how do you guys think a 68 ford mustang hood scoop would look on my third gen
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: hood scoop
if that is the same one that is in the link above then i think it looks to small for the 3rd gen hood.
Re: hood scoop
wow i did see this post geting any action so i hav'nt looked but yea its the same scoop.i have decided not to use it m making a shaker hood with this hood scoop.what do you think.
Car: 1991 firebird
Axle/Gears: 10-bolt 3.08
Re: hood scoop
i dunno it's awfully big to be using as a shaker. It's up to you what you do with your car but i'ld personally wouldn't use it.
Re: hood scoop
well think about it there never been a cowl shaker hood and doing a full size cowl would be silly this unit will sink into the hood and look smaller i will post pics of process
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: hood scoop
i'll be nice and won't say what i'm thinking except to say if you flip it around and lower it I would like it better. then again it will look like a mad max car.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: hood scoop
Trust me, a scoop that tall on the street will only get you in trouble. I have problems looking over my 6" cowl just driving around the pits.
Re: hood scoop
Well the only thing i though would help was i was'nt planing on making it a fiberglass on scoop i wanted to make it a shaker hood so it would it about 2 inchs under the hood
Re: hood scoop
ok im ditching the big scoop and picked up a trans am shaker im going to do i let you see the progress
Car: 87 GTA
Re: hood scoop
here some pics i took today while it was warm out i faced the shaker towards the frount bad idear or good i think it looks cool both ways plus if i open it up forced induction. But there is a down fall i am having secound thoughs about it because this thing has to sit so close that it means i am going to have a hard time buying an aftermarket intake carb i had to do some cuting and this is going to be tricky.Any idears
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
