Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Mini tubb project started
Old Dec 25, 2007 | 12:20 AM
  #101
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Re: Mini tubb project started
XPNDBL3 i was just wondering what width rim you were using with the 6.5 BS a 10 inch right? also what tire are you running on there? who makes the rim? Also did you have any problems with interference with the LCA or anything. I am just finishing up mini-tubbing my car and was looking around for ideas on a setup that would tuck the tires nicely. Thanks for the help.
Greezemonkey your project is looking really good and cant wait to see the end result. Your projects what got me motivated to mini-tub my car so thanks for all the photos and information.
Old Dec 25, 2007 | 12:58 AM
  #102
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
15x10 6.5bs weld pro star
28x12.50 tire and a ton of cutting/reshaping. made a post on the drag board about it a long time ago, search for it. i'm running offset LCAs just like greezemonkey posted a few posts ago.
Old Dec 25, 2007 | 01:27 AM
  #103
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i just want to go on record and say how much i love those wheels! it's lookin' great scott, keep up the good work my friend!
Old Dec 25, 2007 | 10:13 PM
  #104
gtpro700's Avatar
Thanks for the reply XPNDBL3. I was just wondering if you had to offset the LCA's to fit that wheel and tire or is that somethign you did to give you room in the future because i am using a polybushing on my LCA's and there really wouldnt be a way for me to offset them or atleast to my knowledge. Also what is the section width of those tires your running and the tread width? Thanks again.
Old Dec 26, 2007 | 01:58 AM
  #105
xpndbl3's Avatar
Car: 1984 Z28
chro moly double rod ended LCAs that are offset way to the inside. section width and tread width are on the mickey thompson website, I don't remember, I kept cutting until it fit
Old Dec 26, 2007 | 08:15 PM
  #106
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Really having second thoughts on these coil overs in the OE spot, tabs are on the axle already but there is not enough room even using a shorter spring to get the adjusters up higher to clear the tabs...only thing I can do to keep them mounted in near the same location (no other spots anyway) is to create a new upper mounting location just forward of the stock spot, not sure about this one
below is some renderings, basically I would need to fab a "boxed" area for the new mount local, could use a tube to connect and tie them into the roll bar also, just thinking out loud.
Old Dec 26, 2007 | 08:46 PM
  #107
Thanks Matt....don`t you have the same exact ones ???
Old Dec 26, 2007 | 09:14 PM
  #108
mw66nova's Avatar
Engine: 7.0L
why yes, yes i do...your pics inspired me to grab some spare rear springs and cut 2 3/4 coils to see how low i could get the back of the car...look pretty good imho, but it won't work for the track, lol!
i have 15x8's with 4.5" BS, so no mini tubing for me...just rolled the lip and i'm good
Old Dec 27, 2007 | 12:17 AM
  #109
gtpro700's Avatar
mw66nova I know in a nother post you told me you ran a 10" wide tire with 275/60 with a 5.5 BS and this photo your running a 8" with 4.5 is that the same tire? (which i think it is) It looks like this setup tucks a little more am I right? Also why did you do the change ? Thanks for the help
Old Dec 27, 2007 | 01:21 AM
  #110
JERRYWHO's Avatar
Originally Posted by greezemonkey
Thanks...and me too!! these damn coil overs in the stock spot with the adj lower mounts is going to be something else to get in there...I`m not sleeping well now.
With coil overs, control arms and sway bars all in the same area, it's sure hard to make it all fit. On my car I wanted to move the control arm flush with the cut and plated frame rail, tub, shock and small coil over size spring to get the most room from the mini tub job. The only way I can think of to do this is to mount the shock on the control arm. Here are couple pictures of what I'm thinking of doing and maybe it will help you think of a cure for your car.
Jerry
Attached Thumbnails Mini tubb project started-mvc-012f.jpg   Mini tubb project started-mvc-016f.jpg
Old Dec 27, 2007 | 04:20 PM
  #111
no kidding, that`s a different take on it...I would say you have another 1.5-3 inches with the arms moved inboard like that. Jerry what is your car going to be set up for? how wide of a tire are you putting under it? I`m really considering the shock "tower" mod here...I have only one other option and that is to go to the wolfe spring adjusters and just pull the coil overs off the QA1`s.
Old Dec 27, 2007 | 05:31 PM
  #112
mw66nova's Avatar
Engine: 7.0L
there were a number of financial reasons for the change. i needed some money so i sold my rodlites, which were 15x10's with 5.5" backspacing. these wheels replaced the rodlites, nearly a year later when my financial situation changed again. i used the 15x8 because i didn't like the way the 15x10's with 5.5" backspacing fit, and i knew what the 15x8's w/ 4.5" backspacing would look like. also, i'm not anticipating running a wider tire than i am, as i've seen many people running this same 275/60/15 tire go very very fast...i've also seen a 295/65/15 on a 15x8 with no real issues, just gotta run bead screws.
Old Dec 27, 2007 | 06:18 PM
  #113
xpndbl3's Avatar
Car: 1984 Z28
take some time and hit up ls1tech through a google search and look for the mini-tub threads, there should be 50 different ideas at least. Bunch of them are running the coilovers in the rear as well, but that thin stamped steel will not support the vehicle weight as well. Most that I've seen utilize a piece of roll bar tubing running across the floor there to each coilover shock. Haven't studied too much how they tie that in to be load bearing. Hope this helps a bit
10" rim with 5.5bs will have 4.5" sticking towards the outside of vehicle.
8" rim with 4.5bs will have 3.5" sticking out towards the outside of the vehicle.
Therefore the 8" rim would look tucked 1" more.
Now what I have done is mount a 10" rim with 6.5bs which has the same 3.5" sticking out for the exact same tucked look.
Old Dec 28, 2007 | 02:04 AM
  #114
JERRYWHO's Avatar
2.5 inches from the stock location. Just like if you bolted the control arm to the insde of the stock mount.
Most of the time on the street and some street legal days at the drag strip.
Mickey Thompson E.T. street radial 315/60-15 on a 10 wide wheel.
Jerry
Old Jan 7, 2008 | 06:53 PM
  #115
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Gm you still with use hows the car looking, or are you busy shovling snow?
Old Jan 7, 2008 | 07:11 PM
  #116
Hahaaa....ha No! actually it`s 61* out right now!! just took the xmas lights down and went a few rounds with the wii game & the kids. I have the tubs here, and I`m going to move the shocks forward and create a tower, I have already fabbed up a box and the tower will be supported by welding it to the frame and flooring, I also have some roll bar pipe left and I will attach a section to the top of the tower and run it up to the cage to support the area as well, I`ll have some pic`s of progress here shortly.
I gotta say this is taking alot longer than I ever imagined.
Oh and I ordered the Wolfe dbl adj panhard bar...got in on the 20% off sale!
Old Jan 7, 2008 | 07:46 PM
  #117
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Good deal . Hope you and the famaly had a good holidays.
Old Jan 10, 2008 | 06:13 PM
  #118
If that`s directed toward me YES and Thank you! the same to you and yours!
I was injured while at work on the car here a week ago or so..damn metal chip got past the safety glass and I rubbed it right into my eye...well being a mechanic it is nothing new to me, so I tried to get it out for 24 hrs before I gave up and hit the urgent care to have it extracted, I bought goggles after it healed 7 days later..nuff said about that. Now, call me crazy but here`s what I decided to do...there`s no plan, I`m just trying to get it to work with the least amount of resistance! I went ahead and built a couple of shock towers, and as I said above cut some holes to stick these babies up thru....to strengthen it I`m going to tie the shock to the roll bar, it looks like it should work okay, obviously I do not have to worry about a back seat or else this would be a biggie as far as fitting the seat back in.
Okay lets hear it ...good- bad- or ugly
Old Jan 10, 2008 | 06:54 PM
  #119
xpndbl3's Avatar
Car: 1984 Z28
interesting design. I'd also run a crossbrace between the 2 mounts. I'll let someone with more chassis fab knowledge tell you how it'll function/look.
Old Jan 10, 2008 | 07:20 PM
  #120
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Yes I was refrring to you and your family. Good to see you didnt need to go and have it drilled out been there few times. The shock mounts looks good to me.
Old Jan 11, 2008 | 05:41 AM
  #121
I have given up on how it`s going to look, it`s already too to worry about that, I was thinking about a crossbar also.....
No drill, but the doc used a insulin syrign to pick it out, I suggested a REALLY strong magnet but it didn`t surface gotta be the worst thing in the world seeing that needle come at your eye and knowing the doc has said "what ever you do DO NOT look to the left....NO MATTER WHAT" eh okay....
Old Jan 13, 2008 | 08:47 PM
  #122
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Greezemonkey/Jerrywho: The two of you have inspired me to do this mod. What would you guess the total cost and man hours would be for such a mod? I would like to use the wolfe racecraft pre made kit. The shop that did my cage would more than likely get the call on a project like this, so I need to brace for the sticker shock.
Old Jan 14, 2008 | 12:36 AM
  #123
xpndbl3's Avatar
Car: 1984 Z28
20-30 hours at $100 an hour.....wow. Good thing I'll be attempting this myself.
Old Jan 14, 2008 | 05:40 AM
  #124
I have the following into mine
axle housing ends 100
wheel tubs 90
coil over shocks 250
coil over springs 75
labor to shorten and straighten axle housing, cut and respline axles 100
time I have about 20 hrs right now , that is with fabbing a set of new mounts for the coil overs, welding the adj mounts onto the axle and removing all of the stock spring/shock mounts..I have the passenger side shock tower welded in and the shock mounted at this point also. I would guess with the tub kit from wolfe and a shop doing the work 1,500-2,000 but I`m only guessing
Old Jan 14, 2008 | 05:25 PM
  #125
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Very Interesting. I can only hope it will cost less than 5K.
Old Jan 15, 2008 | 01:55 PM
  #126
JERRYWHO's Avatar
My guess.
$1,800 for the tubs, frame rail, Panhard mount and spring work.
$ 600 for new control arms and mounts for full use of the new tubs.
$ 250 to replace rear roll bar down tubes.
Jerry
Old Jan 20, 2008 | 06:53 PM
  #127
alright had some progress this weekend, mocked up the rearend along the coilovers and just let me say these adjustable mounts allow for ALOT of range on ride height, I can lay the frame on the ground OR 4X4 it ! It looks amazing with the 5.5 tucked and a good 2 inches under the fender lip on top of that! I will get pic`s of the car on the ground once I install the axle again..I pulled it to continue onthe sheetmetal work (tubs)
here`s my progress report.
Old Jan 20, 2008 | 07:03 PM
  #128
camarokev400's Avatar
looks awesome you ready to do mine
Old Jan 20, 2008 | 08:23 PM
  #129
sure- winter of 09` less of course, something comes up
Old Jan 20, 2008 | 08:34 PM
  #130
xpndbl3's Avatar
Car: 1984 Z28
looks like it's coming along nicely
Old Jan 21, 2008 | 08:05 AM
  #131
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
looking awesome , i cant wait for more pics.
Old Jan 22, 2008 | 12:22 AM
  #132
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Sweet. The only problem is those dang lower control arms
Old Jan 22, 2008 | 12:24 AM
  #133
xpndbl3's Avatar
Car: 1984 Z28
LCAs aren't a problem if you get offset LCAs. You can further relocated them to the inside if you REALLY needed 18-19" of tire under the car
Old Feb 5, 2008 | 07:53 PM
  #134
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Hows it coming along?
Old Feb 6, 2008 | 05:55 PM
  #135
You know, I logged in this morning and seen the reply but the computer was running really slow & locking....I thought about it on the way to work. I`ve been busy with the front brakes, I got a good deal on a set of new aerospace brakes, I was consumed with that and countless repair work on for friends over the last weekend, modifing the spindles and assembling the parts and installing them onto the car, most of that is done except for the lines. I went ahead and started back up on them tonight...pic`s of progress soon!
Old Feb 9, 2008 | 09:33 PM
  #136
Okay, I`m seeing the light at the end of the tunnel!! had some good progress this weekend ( give me a brake, I`m getting to be an old timer )
Old Feb 10, 2008 | 12:38 AM
  #137
xpndbl3's Avatar
Car: 1984 Z28
looks dang nice to me. Don't worry I haven't even started my mini-tub project yet
I do really enjoy the frictional holding device used to hold up the rear hatch. Looks like it could use a shot of WD40 and a wipe down to bring out that shine. How many inches wide did you end up making the tubs off the outer sheetmetal from the inside of the car?
Old Feb 10, 2008 | 07:44 AM
  #138
Cool man, Thanks... You like that hatch clamp eh? I found those out in the backyard last spring, I think they`ll need to be cut off with a torch when this is done I was thinking of getting a hold of you about that 4.10 gear, I`m getting close to needing it if it is possible, LMK
Old Feb 10, 2008 | 11:43 AM
  #139
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
looking good.
Old Feb 10, 2008 | 05:25 PM
  #140
All right, worked on this pig all weekend, got the axle back in for the final fit & finish, this project is coming to an end real shortly here. One thing I found out is the nasty fuel tank will not take a stock 3rd gen hanger / pump assembly, the sumps baffeled walls prevent it form dropping down low enough to seat, looks like if the assembly was about 1-1.5 inches shorter all would be good...this will be done at a later time. these will probably be the last pictures I post on this thread unless someone wants to see something specifically, it is for the most part done, I painted the inside of the wells and the interior of the wells will be covered by the factory plastic for the most part...oh I`ll post those pic`s when that is done...if it comes out half *** decent that is. Here`s a few shots of the completion of sunday`s work.
The fuel neck hallway..
right side looking up
rh from behind
LH side looking up
LH from rear
wolfe c/m adj panhard
And aerospace front binders from member 2fst4u92z THANKS!
Old Feb 10, 2008 | 05:47 PM
  #141
Almost forgot...this ones for Steve...not even a thought of oil till` it locks up !
Old Feb 10, 2008 | 08:40 PM
  #142
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Looks great I want pics out side in all four tires .And nice pair of grips !!
Old Feb 10, 2008 | 09:27 PM
  #143
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
No problem Just let me know how the Aerospace setup works out.<-- LOL funny b/c it is -2 out side. I would like to see how the stock plastics fit.
Old Feb 11, 2008 | 12:30 AM
  #144
xpndbl3's Avatar
Car: 1984 Z28
haha thanks for the great pic. Still snow on the ground and -3 out, until I get the car on a lift at my buddies shop when it warms up I won't be able to pull that center section out just yet. Hope I'm not holding you up too bad.
Old Feb 11, 2008 | 06:05 AM
  #145
Will do and thanks! I think it`s going to be in the 30`s next weekend so it should hit the ground by then.
I will have to try and do a good job on the plastic now I`ll post up when it`s in and I will let you know about them front brakes, I have already talked to them about a rear set up...they`ll clock the caliper wherever I want it and drill the pattern according to my spec (90* off) with a stock third gen offset of course! I was going to PM you about that csr water pump , still have it? a buddy needs one for a small block if that`s what it fits..PM me.
Okay, the sooner the better though, I`m looking at having it out to practice mid april. Thanks!
Old Feb 11, 2008 | 10:41 AM
  #146
xpndbl3's Avatar
Car: 1984 Z28
ah so march is ok then?
Old Feb 17, 2008 | 04:36 PM
  #147
Pm`d you-
Old Feb 17, 2008 | 05:04 PM
  #148
Well, spent a few Hr`s working with fuel cell this weekend, for one thing there`s no way to get the stock third gen hanger in the tank and still have the float work, the baffling inside this thing is crazy, tall walls that create a "bucket" with a 1.25 hole in the floor going to the sump. The placement of the sending unit mounting hole prevents the float from making a full sweep, even cutting the length wont do it, it angles toward the rear of the tank and the angle is all wrong....maybe a LT1 sender would be a better match.
As I struggled with the stock hanger it became apparent it was not going to work with just a simple cut and splice or tweaking of the angle. To be perfectly honest I had intended on leaving a "in tank" pump in the car for shitz and giggles but it wasn`t in the cards....I cut a 4 inch circle out of 1/8 inch aluminum and used a 5/16 steel tube to mount the stock sender / float assembly too. I then drilled a hole to put a 1&1/4 long 1/4 20 bolt thru (nutted and loctited with a copper washer) another hole for the wiring bulkhead that came from the stock sender. I threaded the 5/16 tube onto the 1/4 20 bolt that protudes thru the aluminum plate and soldered it in place once I knew where it went. I have full travel of the float and it will be as accurate as the O.E tank was. XDone!
Now onto the fuel system, I`ll need to pick up a -10 filter, 350gph pump and some sort of -10 line to run up to the motor , anyone have anything for sale like that?
Old Feb 17, 2008 | 05:44 PM
  #149
xpndbl3's Avatar
Car: 1984 Z28
pics of fuel cell ?
and your PM is fine no big deal.
Old Feb 17, 2008 | 07:48 PM
  #150
pics of fuel cell ?
I`ll snap a few monday. but the plate...I mean "hanger" is already in and sealed.
Ohh and 35 spline..xpndbl3, I meant the pinion, the standard is 28. I WISH I had 35 spline axles, shoot then there would be no wondering if it`ll make it every trip down the strip, = no fun
