Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Dual alternators
Old Oct 18, 2007 | 09:57 AM
darrencarr's Avatar
Car: 87 sport coupe, 85 Z28, 93 S10
Engine: 179ci MPFI,LG4 (soon L98), 4.3L TBI
Transmission: 700r4, none (soon T56), 700r4
Axle/Gears: stock, 3.23, stock
Dual alternators
Ok so ive heard of a few people who swap out their A/C compressor to add in another alternator. I'd like another alternator, however I don't wanna lose my A/C (its a necessity.) So I was wondering if there was an alternator that would fit in where the smog pump fits? Is it a special order type item or is it off of another vehicle?
Thanks in advance guys.
Old Oct 18, 2007 | 12:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Dual alternators
Why do you want dual alternators?
I'm using a larger output alternator to get more juice, 140A out of a CS144. It slips in nicely in a V-belt car.
Do a search on the electronics board to see the thread I posted in. Lots of good pictures and info if you're interested.
Old Oct 18, 2007 | 03:52 PM
darrencarr's Avatar
i get a substantial parts discount to stock replacement parts. bigger alternator is not stock and i then have to buy an AIR delete pulley.
Old Oct 18, 2007 | 04:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
Stock replacement parts? The CS144 I mentioned is the stock alternator for a 1994 Chev lumina van. Or Caprice, or Pontiac Transport van, etc etc. I got mine for $50 at an auto wreckers, but if you get a discount at a parts store you could get it new for.... $150?
Oh, I thought you had V-belts, in that case you don't need a "delete" pulley.
Old Oct 18, 2007 | 11:16 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
chevy lumina is a FWD car right? what van did you pull it out of?
Old Oct 19, 2007 | 03:30 PM
darrencarr's Avatar
the Lumina is also a van, its real name is the "Lumina APV" but for all intents and purposes it was a van on a Lumina chassis (twas an ugly beast too.)
So will the Lumina van alternator fit a serp belt setup? (For clairfication, the engine i'm puttin in is from an '88 L98.)
Old Oct 19, 2007 | 03:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, there's a Lumina car and Van, don't ask me why, neither one was particularly special.
They use a serp belt stock. I swapped the pulley to a V-belt one and it fit into a V-belt setup with only minor tweaking on the brackets.
I think it's an equally common swap on serp cars, but the bracket modification is slightly more involved. Actually, most information online for this swap is directed at swapping it onto a serp belt car.
It also requires one 35ohm or thereabouts resistor to be soldered inline.
Do a google search on F-body CS-144. There's a thread on here, and a tech article on another 3rd gen camaro website with a lot of good info. I'm at work now, but if no one can find it I can dig it up later.
Also, there's a few versions of the CS-144, I think a 105A, a 120A, and the 144A version. I forget now how to tell which is which (big surprise, it's a subtle difference...) But the way to ID them is listed somewhere online...
Old Oct 22, 2007 | 07:17 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
or you could go to o'riely's auto parts or autozone and get a rebuilt 100A for 60 bucks. They go higher too. Why do you need such a powerful alternator? subs or something?
Old Oct 22, 2007 | 08:27 PM
darrencarr's Avatar
yeah i got a couple of 12s and i use em all the time (always have it cranked up) so the alternator get quite a workout. I figure 2 alternators running 90 A would last more than twice as long as one, and how cool would it be to have the only camaro on the block with dual alts?
Old Oct 24, 2007 | 03:46 PM
AmorgetRS's Avatar
Two 12s on any sort of normal Amp won't tax your charging system much. If anything, upgrade your big 3 and call it good.
Old Oct 24, 2007 | 05:13 PM
ryan91rs's Avatar
Transmission: 4L60
more alternators = more drag = less power and economy. Just get one 100A and it will be fine.
Old Oct 25, 2007 | 10:03 AM
darrencarr's Avatar
Good point, I guess ill see if my local alternator shop has anything.
Thanks for the input guys.
RS Reaper
Oct 17, 2018 07:52 PM
zman1969
Oct 1, 2015 11:09 AM
