Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
BIG QUESTION!!
Old Nov 23, 2007 | 12:55 PM
Jassack's Avatar
Car: 1989 TA
Engine: 305, 5.0
BIG QUESTION!!
Ok i saw a thirdgen in a mag and it has 4th gen middle console and door panels. Would it be wrong to copy his ideas and do the same thing? I'm not sure. It's kind of iffy.
Old Nov 23, 2007 | 07:38 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: BIG QUESTION!!
A lot of people put fourth gen stuff in third gens. I'm sure he's not the first to swap the center console and door panels and you wouldn't be the last. If you search on here you can find some threads about swapping the door panels and the console. IIRC the console is pretty simple, but the door panel can be a pain.
Old Nov 23, 2007 | 07:40 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: BIG QUESTION!!
the 4th gen center console is a popular mod, check out the interior section, I don't know about the door panels, they're probably also a popular mod.
Old Nov 23, 2007 | 10:48 PM
Jassack's Avatar
Car: 1989 TA
Engine: 305, 5.0
Re: BIG QUESTION!!
Ok. Thanks for the reassurance. just chewcking cuz i didnt want to be an a$$ and steal someones idea. i know i would be pissed if someone else did that to me.
Old Nov 23, 2007 | 11:08 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: BIG QUESTION!!
If you don't want people to "steal" your ideas, don't brag and/or show them off, because there is bound to be someone that will do it. And just think if you do create a thought in other peoples mind about crossing the 3rd gen and 4th gen boundary then think of yourself as intuitive and that your ideas are worth while :-p. Think of it as people complimenting you instead of stealing your copyright!
Old Nov 25, 2007 | 08:28 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: BIG QUESTION!!
Immitation is the greatest form of Flattery.
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
Leggman1
Aug 6, 2015 04:15 AM
