9" or 12 bolt swap info needed
Car: 89 Z28
Engine: 355 full roller, Brodix 10X heads
Transmission: Close ratio Muncie
Axle/Gears: 3.42/7.5
I'm looking for the thread that has all of the 9" and/or 12 bolt diff swap info. The 7.5 probably won't live long behind the motor I'm building. Any ideas/suggestions?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 9" or 12 bolt swap info needed
Buy aftermarket bolt in 9" or 12 bolt. Take out 7.5" diff, install new diff.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
hop on the drag board, i wrote a very nice step by step assembly process for a moser 9" that has never been stickied but I send a lot of people to that.
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
I run a 9" in my 86 Camaro... I deleted the torque arm and use the South Side Machiene lift bars along with no stock lower control arms and QA1 coil overs behind the axel. Works for me
~Scott
~Scott
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
yes, just remove the bolts that hold in rearend and install new one. It is very easy.
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Ditto on going aftermarket. I picked up a 9", cut all the brackets off, cut the factory ones off and transfered the F-Body brackets to the 9". Took forever, you have to be careful welding. Not to mention making a bracket for the torque arm unless you go with ladder bars or something of the sort. Take it from me. It will cost about the same in the end. I've had to get adjustable control arms and torque arm to account for the slight differences in all the brackets.
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
What about driveshafts/u-joints with the aftermarket rears? 9 inch, 12 bolt....
Car: 87 IROC L98
You buy adapter u-joints to convert the GM 3R u-joint to a 1310, 1330 or 1350 that the 12 bolt or 9" will use.
Thanks! Will the length stay the driveshaft length stay the same? The reason that I ask is that I have a thirdgen aluminum driveshaft and a fourthgen aluminum shaft that I can use.....
Car: 1984 Z28
nice writeup on the drag board would have answered that question
and yes.
and yes.
Car: 87 IROC L98
What's a diff swap and u-joints got to do with drag racing? It would have fit better in the Transmission and Drivetrain board.
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Car: 1984 Z28
Just stating that I already answered the u-joint questions and diff swap questions as the 9" is mainly drag related also.
Terrell351
Jun 13, 2021 01:13 PM
