Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Opinions on offset rear control arms
Old Jan 11, 2008 | 06:18 PM
  #51
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Opinions on offset rear control arms
since we are on the topic of aluminum, i was looking at the prices of 6061-t6, and it would run about 165 bux for a 4' long piece, 4"x6", not really as bad as i would have thought. The aluminum would be the item of last resort, like sonix said, there is always steel, but the weight. The aluminum would be sweet, and i know a very good machinist who can make them. As far as the fatigue rate, people on here run aluminum control arms made of 1"solid and they seem fine, would the aluminum fail with just a compression load?
Anyway, i have to wait till next week to see what Spohn has to say, and we will go from there.
Old Jan 11, 2008 | 06:29 PM
  #52
Stephen's Avatar
Car: 87 GTA
$165 for SOLID 4"x6"x48", or square/round tube? Seems low for solid (but I haven't dealt with any since '96/'97, and high for tubular.
Old Jan 11, 2008 | 06:44 PM
  #53
//<86TA>\\'s Avatar
Car: 86 Trans Am
yup and thats with shipping.
It also depends on where you look, some places are almost 5 times that... its good to know people
Old Jan 11, 2008 | 06:58 PM
  #54
Stephen's Avatar
Car: 87 GTA
I'd say so!
I was going to build me one 1 piece billet valve covers. Milled out of a solid piece. Sure, it woulda been a HUGE waste of material, but I wouldn't have had to pay for the machine time. I coulda just come in early, late, or a Saturday to do it, or if another machine was idle, I coulda used it. That's how I milled the derby Camaro. I used an idle machine!
Makes me wanna build some 1 piece ones now. Imagine having WS6 or GTA, or Z20 or FIREBIRD or CAMARO, either machined INTO the top, or the excess material being machined off, leaving them "embossed"!
Old Jan 11, 2008 | 08:03 PM
  #55
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Thad be awesome!
Old Jan 16, 2008 | 03:37 PM
  #56
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
If you really want to build your own try using flat stock and tracing the basic shape to it making 2 pieces, for the top and bottom, take to more pieces that are cut to the height wanted and longer to accomodate the bends, then weld all pieces together to basically create a box. Hopefullly this makes some sense to a few people. I will try and draw up exactly what I am talking about.
Old Jan 16, 2008 | 03:43 PM
  #57
Stephen's Avatar
Car: 87 GTA
That makes sense, but I wouldn't trust such LONG welds, especially since they'd be at the stress points....the corners of the fabricated "device".
Old Jan 16, 2008 | 03:50 PM
  #58
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
the pieces that are standing on end would not be all the way to the outside, move them inboard ~ the width of your weld fillet (3mm). BTW how much are you planning on "beating" on the car...ie...drag racing, autocross, or just a show/go toy?
Old Jan 16, 2008 | 06:12 PM
  #59
//<86TA>\\'s Avatar
Car: 86 Trans Am
im trying to use a rod end on one side, so a boxed design isnt really where im heading.
Its a street car, built to handle and may see some autox in the future
Old Jan 20, 2008 | 06:31 PM
  #60
//<86TA>\\'s Avatar
Car: 86 Trans Am
Steve over at Spohn told me he was planning to start these things yesterday, so thats good news. I dropped the wheels off at the Wheelworks to be widened, and should have them back late this week, then i can pickup the tires and start cutting, should keep me busy for a little while. Its just a shame i need to pull out the rear interior again.... I guess practice makes perfect
Old Jan 24, 2008 | 01:55 PM
  #61
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I can't believe how long this thread is. I autocross and have been wondering what it would be like to have fat tires like that on my car but wow... thats a lot of work to get an extra inch of rubber to the ground (two inches total right? 1in for each tire?). I don't know much about the forces that would be applied to the LCA, but wouldn't it want to twist any time you hit the gas? I know thats why you want to have the rod ends, but I would think it would still want to twist way more than a normal straight LCA if you would accelerate out of a turn.
Anyway, I cant wait to see it installed.
Old Jan 24, 2008 | 08:26 PM
  #62
//<86TA>\\'s Avatar
Car: 86 Trans Am
i dont think they would want to twist, by the design, just looking at it, if any movements would occur it would be bending inboard, but its such a short piece that i dont think it will happen.
It is a bit of work but, but i get bored in the winter time, my mind starts wandering , and things like this happen....
I cant wait to see what steve comes up with for the final piece
Old Jan 28, 2008 | 09:17 PM
  #63
//<86TA>\\'s Avatar
Car: 86 Trans Am
I got a call from Steve Spohn to day, and the arms are done! just need to be powdercoated, and i should have them next week. He seemed very interested in them and mentioned that he may use the design for a catalog item, so thats pretty cool . Cant wait to see what he came up with and see if they fit like they are supposed to.
Old Feb 6, 2008 | 09:30 PM
  #64
//<86TA>\\'s Avatar
Car: 86 Trans Am
they showed up today and here they are, they even fit
Old Feb 6, 2008 | 09:39 PM
  #65
Stephen's Avatar
Car: 87 GTA
Hmmmm....I'd prefer to see the 2 tubes attached, then a plate over the "valley" boxing them together, than rely on the 2 curved tubes touching.
With such big tires, those points are gonna getting a lot of stress from launches and cornering.
Those may be perfectly fine. But in my building experience, I wouldn't trust those FULLY.
My
Old Feb 6, 2008 | 09:41 PM
  #66
white91formula's Avatar
Car: 91 formula
Transmission: t5
ick, scary !!!
you wouldnt catch me with those on my car !
good luck with that, and i hope it lasts
Old Feb 6, 2008 | 10:11 PM
  #67
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
Please explain to me why you can't use square or rectangular tubing and rod ends.
Old Feb 6, 2008 | 10:13 PM
  #68
//<86TA>\\'s Avatar
Car: 86 Trans Am
ive never heard of a square tubing adapter .
All i know is, the guy who built these things builds suspension and chassis parts for a living and saw no issues with strength with the design. I may be naive (spl), but that gives me some comfort in their construction. I'll just have to keep an eye on them and see how the hold up
Old Feb 7, 2008 | 08:09 AM
  #69
Car: 91 formula
Transmission: t5
well hopefully if something happens to them, he will stand behind them
Old Feb 7, 2008 | 09:38 AM
  #70
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I would tend to agree with this statement but with round tubing no matter where you weld it the tube gets weaker. So if there was a strap it would just move the weakened area.
I truly hope you do not have problems with these ever but even if Steve made them (as opposed to myself) I would not use them on my car
Make sure you post pics when they are on the car! They still look nice
Old Feb 7, 2008 | 09:51 AM
  #71
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
They don't look strong, but sometimes your eyes don't tell the whole story.
If Spohn himself is willing to brand it with his name, knowing you frequent forums, knowing you are fully willing to post pictures of a destroyed Spohn product and the carnage that happened to your car - i'm guessing he has a decent idea how strong that will be.
Old Feb 7, 2008 | 12:13 PM
  #72
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it looks like using off the shelf double rod ended offset LCAs would have given you essentially the same offset and been stronger. I wonder how well those will live with potholes and everything else a street car will encounter.
Old Feb 7, 2008 | 12:24 PM
  #73
Sonix's Avatar
Car: 1982 Trans-Am
Wait, what? who makes that??
Old Feb 7, 2008 | 02:58 PM
  #74
Stephen's Avatar
Car: 87 GTA
The only off-the-shelf offset ones, that I've seen, only give about 1/8" offset. Not a couple of inches like his.
Old Feb 7, 2008 | 03:09 PM
  #75
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
I know it would be expensive but. I would like to see the same shape made out of one bent pice of tube. It can be done just not on a standard bender. Or one piece billet LCA. Like this but with the curves.
Old Feb 7, 2008 | 06:08 PM
  #76
//<86TA>\\'s Avatar
Car: 86 Trans Am
i drew up plans for these arms in billet a month or so ago. Its the "plan b".
as for the off the shelf spherical ended offset arms, they dont have quite enough clearance, the tire will at least touch them, things are very tight in there.
actually, xpndbl3, you have those arms on you car dont you? when you get a minute and want to make a measurement for me, what the measurement form the face of the rotor/drum to the arm?
the negative vibes are unreal......
Old Feb 7, 2008 | 06:39 PM
  #77
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Sign me up for a set if they work. I bet they will!
I would love to tuck my 315's a bit more.
Old Nov 29, 2009 | 06:33 PM
  #78
//<86TA>\\'s Avatar
Car: 86 Trans Am
found this while searching, search does work!
Any way, i've beaten on these arms pretty hard for almost 2 years now with no issues at all. Still dead straight. Working like a charm.
Old Nov 29, 2009 | 06:39 PM
  #79
Stephen's Avatar
Car: 87 GTA
Too bad the last post in it, was from almost 2 YEARS AGO!
Old Nov 29, 2009 | 06:53 PM
  #80
//<86TA>\\'s Avatar
Car: 86 Trans Am
yes, and? 1 year, 9 months
Old Dec 1, 2009 | 09:36 PM
  #81
85TransAm406's Avatar
Car: 1985 Trans Am
I'm suprised at the negatives as well, I plan on doing the same to fit 335s as well. The welds will be as strong as, if not stronger than the tubing IMO. I'll be using ER70S tig rods, which have a 70,000 PSI tensile strength. With the welds on both sides of where the tubing meets, it's basicially 1" thick solid weld. When welding 1/2" solid plate for my AWS certification, we grind a "V" into the plate and weld in multiple passes, weaving one bead into another (MIG). we then then bend the plate at the welds 180* on a 3/4" radius in either direction, and if it was gonna fail, it would fail then. And when bent, it's almost impossible to see the actual weld area without an untrained eye. You are essentially creating 2 "V's" welding it solid. Capping the ends of the tubing pretty much eliminates the weakest portion of the design. I'm just the welder/machinist, so I have had the Mechanical Engineer at work run the modeling to check my theory, he said in typical suspension cycling, assuming I don't put it in a wall, it'll still be less likely to fail than stock.
Old Aug 1, 2015 | 10:58 AM
  #82
//<86TA>\\'s Avatar
Car: 86 Trans Am
Searching around again and dug this back up.
its 2015 and I'm still alive and these arms are still holding up well.
amazing how time flies though, I can't believe its been almost 7 years
Old Aug 6, 2015 | 10:42 AM
  #83
83RDRACR's Avatar
Did Spohn ever make these a catalog item?
Old Aug 6, 2015 | 11:21 AM
  #84
//<86TA>\\'s Avatar
Car: 86 Trans Am
I don't think so but last I spoke with him he had them hanging on the wall so I assume he could still make a set if asked
Old Sep 6, 2015 | 06:25 AM
  #85
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I asked about 5 months ago if I could get a set, spohn said no problem. I did not order them since I don't need them yet, but they say they have the drawings to make sets if need be.
Old Sep 7, 2015 | 11:38 AM
  #86
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
It's great to see a long term evaluation on a product such as this. Good Job!
Where are all the naysayers now? If more members would post long term results the community would be better off than many members reporting on the same product in the short term. Great to hear those worked so well for you and am really surprised Spohn didn't catalog them.
Old Sep 15, 2015 | 08:27 AM
  #87
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Sounds like he can make them real easy, prolly such a low demand that it doesn't pay to make them and have them sitting though. That's cool that he keeps schematics for things to build to order like this though.
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
