soooo, what do your switches do?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: soooo, what do your switches do?
Vac has been disconnected because I now use a belt driven vacuum pump.
Car: 1988 Camaro
Cooling fan
elec. helper fuel pump
Ignition system/coil power
Starter button
Memory Recall for my speedo/performance meter/tach
Line lock (roll stop as some call it)
th-400 elec kickdown/detent (some call it the "passing gear")
Starter button
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Car: 87 IROC L98
It's custom made. Wires are coming out on the front side so that they can go along the halo bar of the roll cage.
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I have 3.....
METH, 2-step, second fan
Oh, and a button for my line-loc
Car: 1983 Z28
Engine: 385 Fastburn
I have 2 (though one is factory lol) rear defrost and fuel pump. Also a button for the line lock.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Radiator fan manual override, lights mounted under the wiper cowl, subwoofer amp disable (for when the kids are in the back), horn switch(toggles between OEM horn/dukes of hazard horn) all mounted in the ashtray along with a pair of USB charging ports. Pushbutton start mounted where the cigarette lighter was. Rewired the cruise on/off switch to enable/disable the low beams in the inner pair of headlight bulbs. Gives me twice the light output on low beam, and I never liked cruise control.
Car: 1983 Z28
Ignition, Date/Time Computer, Primary Cooling Jets, Flux Capacitor, Wait....wrong car.
Car: 88GTA
Engine: 5.7TPI
Car: 1983 Z28
Randomtask2
Sep 10, 2015 08:37 AM
