Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
CNC plastics
Old Jan 21, 2008 | 09:11 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
CNC plastics
ok, what I have in my firebird Is a 6-speed so.... I want to take the 5-speed shift pattern and make a 6-speed pattern that looks 99% or as close to the same look but showing the t56 pattern. (this way it still has the numeric numbers that light up at night)
now I am no CNC guy at all but i know someone who can make the pattern in autocad for me. would it be possiable to have this made at a shop with a CNC with little trouble using the cad specs? or is this some major under taking for a CNC operator
Old Jan 21, 2008 | 11:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: CNC plastics
That's definately doable. You'd need a new piece of plastic right? I don't think the pattern is such that you can simply cut your existing one right?
Ask the CNC operator, each CNC setup is slightly different. If they have the software to import a 3D MODEL (not some stupid 1980's 2d crap) into their CNC modelling software, then it's easy as pie.
Ideally the shop should be experienced in machining plastics, it's a whole different ballgame from steel or aluminum.
Old Jan 22, 2008 | 08:51 PM
Engine: ls1, LB9
Re: CNC plastics
cool thant's what I would like to here/ yes the program is current stuff as he does this for his job. now I need to find a place to ask
Old Jan 22, 2008 | 09:02 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: CNC plastics
with that easy of a job screw the program they can go into override mode and do it with the zero out function while having the bit spinning. It would take five minutes and cost you probably a ton. lol!
Old Jan 22, 2008 | 09:38 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: CNC plastics
you mean like this??
Old Jan 24, 2008 | 06:57 AM
Engine: ls1, LB9
Re: CNC plastics
yes
Old Jan 24, 2008 | 09:33 AM
Engine: LO3
Re: CNC plastics
LOL hawks third gen sells them. It's like 25 bucks I think. Look in the 82-92 firebird section, interior section, center console section.
Old Jan 24, 2008 | 07:28 PM
Engine: ls1, LB9
Re: CNC plastics
ok, thanks I thought there was a guy selling them wayback but our search eng. never showed it
Old Jan 28, 2008 | 01:31 PM
Stephen's Avatar
Car: 87 GTA
Re: CNC plastics
I looked all over Hawks site....Couldn't find them. Link?
Old Jan 28, 2008 | 06:04 PM
Parasoth's Avatar
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
Re: CNC plastics
Firebird 85-92 Shift Indicator 6 speed conversion
http://hawksthirdgenparts.com/index....ROD&ProdID=543
Old Jan 28, 2008 | 06:29 PM
chevboy28's Avatar
Car: 1992 25th anniversary camaro
Engine: 406
Transmission: t56
Axle/Gears: 410s
Re: CNC plastics
i got one with my crossmember from spohn
Old Jan 29, 2008 | 09:14 PM
Engine: ls1, LB9
Re: CNC plastics
as for the hawks insert, I think it lacks the factory look a bit ...
I don't think I can sell enough of what i want to build to offset the cost on my end. I do have another Idea that I think would just plain rock. but I don't want to let the cat out of the bag until I have it done if I even bother having it done
Old Feb 3, 2008 | 09:08 PM
chevboy28's Avatar
Engine: 406
Transmission: t56
Axle/Gears: 410s
Re: CNC plastics
spohn sells them and they look more authentic
Old Feb 3, 2008 | 09:33 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: CNC plastics
so does the 6 speed, but to each there own i guess, i remember way back seeing some on ebay, couldnt find it for you tonight when i searched
Old Feb 3, 2008 | 09:38 PM
Engine: ls1, LB9
Re: CNC plastics
didn't really want the 6-speed but no one would help out just the trash talk on how the t56 is soooo great anyway it's what I have and I have my car looking like a factory setup through and through so I just want the fine details to match
Old Feb 3, 2008 | 10:14 PM
89RS_82Z's Avatar
Re: CNC plastics
yea well a six speed is more fun, the gears are a little closer to each other, i cant say if i would put a 5 speed back in it or not if it were mine, but givin the 6 speed aint stock, i think that the one on hawks is close enough, couldnt find the spohn one .......
one thing if you wanted that all stock look, you could sell the 6 speed and have enough money to get a 5 speed with a fresh rebuild, short throw, and a good clutch
Old Feb 4, 2008 | 09:09 PM
Engine: ls1, LB9
Re: CNC plastics
the one I had was rebuilt with the super alloy cluster gear, 3rd and I belive I had the new input shaft but i sold it with the papers so I can't recall what I had into that one.
the way I really wanted to use it is until i could get a tko which would have been a very similar fit. I guess what is done is done though . I did get the hawks insert and I bet sophn was selling one of hawks inserts they may have a first batch or something. since they like to sell stuff for each other. spohn just has a better setup when it comes to paying for stuff online (shipping prices on the spot ) thanks for the help and
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
MrPackstin
Oct 25, 2017 08:09 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Night rider327
Sep 25, 2015 04:19 AM
ericjon262
Sep 11, 2015 06:07 PM
