Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Subframe material
Old Feb 6, 2008 | 07:27 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
Subframe material
Hey guys,
Does anyone know what size tubing is used for subframes, both the diameter of the tubing and the wall thickness of it ?
i assume its 1.25, it looks smaller then your average 1.5 for roll cages.
if anyone can let me know that would be great
Thanks, Keith
Old Feb 6, 2008 | 08:56 PM
Car: 91 formula
Transmission: t5
Re: Subframe material
i figured it out guys, this can be deleted
Old Feb 7, 2008 | 09:16 AM
Stephen's Avatar
Car: 87 GTA
Better than being deleted (threads aren't deleted), you can share your findings with the rest of the class. I'm sure it's posted elsewhere, but it never hurts to have it recently posted at the top of the Forum.
Old Feb 7, 2008 | 07:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I never made mine but I think it's 2" x 2" x .134" (or less) wall square tubing. It doesn't need to be very heavy.
Roll bars are 1-3/4" tube. Roll cages are mostly 1-5/8" tube.
Old Feb 22, 2008 | 02:08 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I used 1 1/2 x 0.090 wall square tubing for mine.
Old Feb 22, 2008 | 03:28 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
2"x2" mild steel tubing for mine... thickness was prob .100 or something i got it off ebay and just made my own with the material
Old Feb 22, 2008 | 04:48 PM
Guest
Guest
Posts: n/a
Are you talking about the car's 'subframe' or subframe connectors?
Spohn's are 1.75" OD 0.120" wall thickness round steel tubing of unknown to me yield strength. UMI's are 2.00" x 1.25" 0.120" wall thickness rectangular steel tubing of unknown yield strength as well. IIRC my SSM connectors are 2.0 x 1.5 0.120 wall but weak side rather than strong side in orientation, 36ksi yield strength from what I found on them years ago.
Old Feb 22, 2008 | 07:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
alstons are 1.75x.120 or .134 round tubing
Old Feb 22, 2008 | 10:21 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
That is a bit on the thin side unless it is 4130 material.
When I made mine I used tubing that was 1 3/4" DOM. The wall thickness is .134 The mounting plates on the front are 7ga (3/16") mild steel and the rear mount is attached with a two part mount system. The first part was welded in prior to the SFC and is a U shape part that was welded in 360 degrees and form fitted in there. It was about 7" long. Then the rear of the SFC slid up in there and was welded along the sides and bottom. (hard to explain but worked out great and made for a perfect fit!)
I have a air/hyd mandrel bender. So you can do it different but this was how mine were made.
See attached links for pictures and fabrication of the SFC's
https://www.thirdgen.org/forums/su...-wont-fit.html (what SFC's wont fit longtubes?) (what SFC's wont fit longtubes?)
https://www.thirdgen.org/forums/ex...html?highlight (My exhaust picture) (My exhaust picture)=
https://www.thirdgen.org/forums/fa...html?highlight (1982 Z28 Silver State project) (1982 Z28 Silver State project)=
MrPackstin
Oct 25, 2017 08:09 PM
Nervous2
Oct 8, 2015 10:53 PM
tmork454
Sep 29, 2015 06:33 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
