Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
steering box awnsers needed
Old Apr 19, 2008 | 09:08 PM
twins's Avatar
Car: 88 gta
Engine: 350 turbo
Transmission: t5
Axle/Gears: 4.56
my power steering pump is hitting my rad. will a s10 pump clear? i.e. is it much if any shorter than a factory pump? i couldnt find any awnsers on the topic.
thanks in advance
Old Apr 19, 2008 | 09:33 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: steering box awnsers needed
How is your power steering pump hitting your radiator? Picture please.
Old Apr 19, 2008 | 10:24 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
I agree... I'm confused
A s-10 manual box will fit just fine, not sure about a PS box??
Old Apr 21, 2008 | 11:22 PM
Comp788's Avatar
BUMP.
Where is the picture???
Old Apr 22, 2008 | 11:43 AM
madhatter's Avatar
yes the s10 manual steering box is shorter, however you have to trim up the sway bar braket a bit to get it to fit, however i dont get how it could be hitting you radiator
Old Apr 29, 2008 | 12:58 AM
oil pan 4's Avatar
Car: 89 Firebird
Radiator swap/up grade maybe?
Old May 6, 2008 | 10:04 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
He probably rear ended some poor slob and pushed his whole front end back about 8 inches..
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Street Lethal
Aug 13, 2015 08:28 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
