Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Floor pan replacement
Old Sep 8, 2007 | 01:26 AM
pi_88vert's Avatar
Car: 88 convertible iroc
Engine: 305 tpi
I am trying to decide if I have the ability to cut out and replace my floor pans. I know i have seen posts where people have detailed the process but i just cannot find the one i am looking for.
Can anyone give me a step by step from cutting out to replacing. Pics would be a great help if possible.
Also one of my seat rails is badly infected and i need ideas for fixing this problem as well.
I think i can do it from what i have seen but do not want to attempt w/o all the neccessary info.
Old Sep 17, 2007 | 01:59 PM
rhamm1320's Avatar
Re: Floor pan replacement
Here is a Mustang article with pictures that may help:
http://personal.ecu.edu/boydd/tech/f...floorpans.html
Keep in mind, how difficult or easy it will be will depend on your skills, tools available and if you allot yourself enough timeframe to do a good job. It may look easy when someone else does a write up. I did it 'twice' myself. First time I was in a hurry and wanted to get it done before work Monday and it showed in the results. Later, I cut that one back out and did it right.
Old Sep 18, 2007 | 12:07 PM
pi_88vert's Avatar
Engine: 305 tpi
A big thank you for that link it is just what i needed. Now i have something to refer to as i go. Agian thank you very much
Old Sep 27, 2007 | 11:17 AM
Aerosmith's Avatar
Car: 1982 Camaro, 1985 Z28
Engine: 383, 305
Transmission: TH350, T-5
As rhamm said, take your time and do it right the first time. I would suggest assembling everything before you start: saw blades, spotweld cutters, mig welder and on and on. Just a guess from your screen name, if it's a convertible you have alot more prep than a hard top does. My first floor replacement was on a VW 'vert and I learned a few things the hard way. You need to brace everything before you start cutting out any of the pan or when you finish your doors won't close and your top will not seal.
Old Sep 27, 2007 | 09:17 PM
pi_88vert's Avatar
Engine: 305 tpi
where should ii place the braces???
Old Oct 6, 2007 | 08:30 PM
Mathius's Avatar
https://www.thirdgen.org/forums/fabr...t=#post3317641
Old Oct 8, 2007 | 10:42 PM
pi_88vert's Avatar
Engine: 305 tpi
Thanx for the link but i decided to send the car to a welder. Very soon i will be posting pics as i will be putting my interior back in.
Old May 10, 2008 | 03:51 AM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
So wat happen to it. I want to see some pics because the links dont work. I have found some really bad rust on my pans and they need to be fixed ASAP but its not an emergency. like I need to do it now
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
MY87LT
Aug 17, 2015 08:43 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Amillionoh7
Aug 7, 2015 01:24 PM
