Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
can a ls1 camshaft work in my firebird
Old Jun 29, 2008 | 10:19 PM
cjohn310's Avatar
Car: 1992 FIREBIRD
I was told that a ls1 camshaft will work in my 1992 firebird LO3 engine and will be a performance upgrade and if so what els should be done in the swap
Old Jun 30, 2008 | 02:25 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: can a ls1 camshaft work in my firebird
No, you cannot use an LS1 camshaft in any regular chevy engine. Perhaps you heard about an LT1 camshaft? Those will bolt in. Look at the TBI forum, there is a sticky post about it.
Old Jun 30, 2008 | 03:54 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
ditto, its going to be a lt1 camshaft
Old Jul 1, 2008 | 08:11 AM
cjohn310's Avatar
Car: 1992 FIREBIRD
hey thanks for the info on the camshaft im trying to rebiuld this car and the guy who had it before had know idea what the dif from a wrench and a screwdriver. so thanks a lot.
Old Jul 1, 2008 | 01:21 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
would a lt1 cam work in a 350 l98 trans am?
Old Jul 3, 2008 | 11:32 PM
Pocket's Avatar
Car: 91 Trans Am
Not much bigger than stock, but yes it will fit
Old Jul 3, 2008 | 11:35 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
get an lt4 cam supose to be pretty good in the l98s. i believe u have to upgrade the springs too though...
Old Jul 4, 2008 | 12:18 AM
Pocket's Avatar
Car: 91 Trans Am
No need for speculation, plenty of documented swaps are on the forum
A simple search will yield all necessary info on LTx cam swaps, benefits and requirements
Old Jul 4, 2008 | 12:19 AM
87transGTA's Avatar
Car: 87 GTA
so u think id be better off just gettin new heads and an aftermarket cam?
Old Jul 4, 2008 | 12:28 AM
Car: 1991 Z28 1LE
Transmission: 4l60e
o yeah cant go wrong there, well other then the whole restrictive tpi setup...maybe invest the money in some aftermarket tpi junk then get the heads and cam
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
reiderz iroc
Aug 13, 2015 04:57 PM
