Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
running new fuel lines
Old Sep 23, 2008 | 08:15 PM
squeeezer's Avatar
Car: 5 cars
i already sumped my factory tank
waiting for parts to show up
-8 line to a mechanical pump -6 from the pump to the carb
second fuel system for n2o
-6 line to summit pump to fuel solonoid
my question is anyone have pics as to how the lines were run?
Old Sep 23, 2008 | 09:21 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Re: running new fuel lines
try to fallow the stock routing as much as possible, keep from all moving parts and exhaust...ive done it with -10 and the only way to do it...get under the car and do it...
Old Sep 23, 2008 | 10:38 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I pretty much put it where the stock lines were. Just instead of going over the trans, I brought it up the driver side.
Old Sep 24, 2008 | 06:19 AM
squeeezer's Avatar
Car: 5 cars
like the newer 3rd gens???
Old Sep 24, 2008 | 11:05 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I suppose the newer ones route my way, never seen one. I just got it to my fuel pressure reg by the wiper motor:
Old Sep 26, 2008 | 06:35 AM
squeeezer's Avatar
Car: 5 cars
i ran em down the passenger side
both fuel systems
if i like em like that ill mount the lines with the hold downs today
Old Sep 26, 2008 | 07:48 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
http://www.cecoatings.com/images/oth...o/DSC_8300.JPG
http://www.cecoatings.com/images/oth...o/IMG_1344.JPG
http://www.cecoatings.com/images/oth...59.JPG%202.jpg
http://www.cecoatings.com/images/oth...o/IMG_1360.JPG
Old Sep 28, 2008 | 09:32 PM
squeeezer's Avatar
Car: 5 cars
you do very nice work!!!!!!!
Old Oct 3, 2008 | 03:03 AM
seb.a's Avatar
Car: 1983 Trans Am MSE
Engine: LG4
Transmission: TH700R4
Axle/Gears: 10 bolts 3.73
hi,
very good work!
is it home made fuel lines or an aftermarket systeme ?
Old Oct 3, 2008 | 11:47 AM
jfg455's Avatar
Car: 89 formula *sold*
Engine: 305TPI
Axle/Gears: 3.45 9 bolt
TPI383 thats a sweet set up! Nice work.
[quote=squeeezer;3897202]i already sumped my factory tank
You have any pics of your sump? I'm looking to do the same. How about muffler clearance? I was thinking a borla XR1 would clear.
Old Oct 6, 2008 | 07:05 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
TPI 383 wow! frigin amazing! great job... sumone paid alot of money for that
wat about running new fuel and brake lines up over the trans straight in the center of the tunnel from the rear of the tank? sumhow get around the Ebrake thats in the trans tunnel. there is room above it for that. would get the lines away from the exhaust heat, and ground debre... as well as the street salt and water and would never probably rust?? totally hidden as well. just a suggestion. gona be doin that for my 383 HSR engine swap
Old Oct 7, 2008 | 06:12 AM
jfg455's Avatar
Engine: 305TPI
I would be more worried about a broken drive shaft making a firey mess if the lines were in the tunnel area. Specially with a big pump pushing it.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
