Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
suframeconector and ladder bar
Old Dec 14, 2008 | 02:57 AM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Axle/Gears: 9 inch 3.25/4.11,axles moser 31 spl
tell me if this is the correct way to build the SUFRAMA to install ladder bar?
so what construllo "stephen 87 iroc" in its web
speak and say whether it is right to do the same. Please, advice, photos Help??
Old Dec 14, 2008 | 10:01 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: suframeconector and ladder bar
My SFC were custom made. I simply welded a ladder bar crossmember between the SFC.
Your picture isn't loading
Old Dec 14, 2008 | 12:14 PM
mexicanknight's Avatar
Fixed that apperently he wants to do the same thing
Old Dec 14, 2008 | 12:59 PM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
The picture loads for me.
Old Dec 14, 2008 | 11:08 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
1- this is its work in your car?
2- you did suframe with sweet iron squared 2x2", rectangle 3x2" ?
3- I must connect the back chassis to the front chassis (forming a single chassis) ?
Old Dec 14, 2008 | 11:39 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
to weld suframe of back to the front
Old Dec 15, 2008 | 12:15 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Like I've already said. Mine are custom made. The subframes themselves are just 2" x 2" square tubing. The rear part is modified to attach to the rear subframe. They don't run parallel to each other.
Subframe welded to front
Subframe welded to rear
Old Dec 15, 2008 | 05:01 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
1000 thanks. that photo is what I want to see
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
