Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
TPI ram air.
Old Sep 3, 2008 | 05:43 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
TPI ram air.
Fiberglassed a ram air last weekend. Came out pretty good. here are some pics.
My mold wasnt the greatest... I didnt spend too much time on it.
Old Sep 4, 2008 | 01:57 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: TPI ram air.
Thats a nice Idea. Looks good!!!
Old Sep 4, 2008 | 05:14 AM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Re: TPI ram air.
Looks like Jar Jar Binks.
Never seen anyone fiberglass them before! Pretty cool.
Old Sep 4, 2008 | 02:52 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Re: TPI ram air.
neither have I so I htought I would try it. Came out pretty good.
Old Sep 4, 2008 | 06:03 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Re: TPI ram air.
thats pretty cool man...tell us more...how did u go about making the shape? any more pics??.
Old Sep 6, 2008 | 02:36 AM
86irocu's Avatar
Car: 1986 Iroc-Z
Re: TPI ram air.
just used cardboard for the mold. Then covered the outside of the cardboard with wax paper (easire than using a lifting agent and less time consuming. Then made sure it fit then fiberglassed it... I had to make sure i fiberglassed it to the plastic... Its pretty sturdy. These are the only pics i have of it.. I didnt get a chance to take any before i put the glass on it... It grabs air from where the fog lights are and a little underneath.
You can see I didnt get all the wax paper off yet...
Old Sep 8, 2008 | 04:49 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: TPI ram air.
Could you post up some of the dimensions you used? What had to be cut out? How easy is it to slip in? How did you attach it to the plastic?
Old Sep 10, 2008 | 12:06 AM
86irocu's Avatar
Car: 1986 Iroc-Z
Re: TPI ram air.
I made it out of cardboard first... There really werent any dimensions involved... The cardboard mold was cut to fit inside of the plastic intake piece. Then I cut the curved cardboard with it on the car... to get it where I wanted. Instead of using release agent I covered the cardboard mold with wax paper. Then I fiberglassed the mold while it was still attached to the plastic piece. After the first layer was on and dry i fiberglassed the first layer to the plastic. each layer afterwards was fiberglassed to the plastic. Its easier to use fiberglass mat rather than cloth. the mat is much stronger after the resin cures. It is a snug fit, nothing hard to be cut out.. Just be careful where you get resin on the plastic piece, you dont want to get it in the holes that are used to lock the top part of the intake on.
Old Sep 20, 2008 | 01:26 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: TPI ram air.
cool idea...punn intended. the only thing i would be concerned with is the air flow to the radiator being obstructed too much. keep an eye on your temp! these cars are prone to overheating as is, never mind when you divert all the air into the intake instead of the radiator.
Old Sep 26, 2008 | 02:50 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Re: TPI ram air.
my car runs at 180 with or without the ram air. the air dam is still there... therefore air still gets pushed up into the radiator. but thanks for your concern...
Old Dec 13, 2008 | 09:17 AM
mattyc's Avatar
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
Re: TPI ram air.
have you seen any noticeable performance gain from this.
Old Dec 14, 2008 | 05:22 PM
Car: 1987 IROC-Z
Transmission: TH350
Re: TPI ram air.
I heard that throttle response might be better but it would be nice to hear from someone who actually uses it.
Old Dec 14, 2008 | 06:09 PM
gunner53227's Avatar
Car: 86 TRANS AM
Transmission: 700 R4
Axle/Gears: 10 bolt/3.73
Re: TPI ram air.
It would look alot better if you threw a coat of paint over it.
Old Dec 15, 2008 | 03:45 PM
JMR's Avatar
JMR
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
Re: TPI ram air.
i was brainstorming something similar but for the same reasons that irockid86 stated my thing was or is having the entrance behind the foglights therefore having the air dam fully functional w/out restrictions.
but if you have no problems more power to ya
Old Dec 15, 2008 | 10:16 PM
Car: 1987 IROC-Z
Transmission: TH350
Re: TPI ram air.
How much do you think leaving the fog lights in would impede the air flow using this design. I plan on building this this winter but I'm not getting rid of the my fog lights... and I'm not going with those ugly tiny round ones sold at Autozone or something.
Old Dec 16, 2008 | 05:27 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: TPI ram air.
if your planning on fiberglassing in the winter think again. ive done lots of work in fiberglass... and i just posted a new AC delete box thats 100% fiberglass and i just finished that about 4 days ago... i used extra hardner in my resin mixes bc i can work faster and not waste time. but for sum reason the cold (20-35 degrees) did not allow the resin to cure fully. it stayed fexable even after 24hrs cure time in my garage. i then brought it in side and let it cure for 6 hrs and it was fine. i did everyhting inside at room temp and u dont want to be fiberglassin inside. the stench will go everywhere. whent through 3 floors in my house and sticks around for alil while after ur done. i also kno that fiberglass is a chemical reaction and doesnt need warm temps to work bc the chemical reaction actually causes heat... but the evidence says otherwise, ive only fiberglassed in warm temps before this. fiberglass is also messy... it would come out cleaner if u used aluminum(thin) or even tin (AC ducting) and just screwed/riveted it together. just throwing that out there.
sure fiberglass is easier to mold and light and will prob get the job done. but not to knock the job (he stated he didnt spend alot of time on it) its looks need sum serious attention. u then have to paint it and deal with it or bondo it and sand and bondo and sand etc and then paint. Knock it out 1-2-3 with homedepot aluminum and rivets in 3 hrs and u can even polish it or paint but the work is done for u
Old Dec 16, 2008 | 08:06 AM
mattyc's Avatar
Engine: 350 tpi
Axle/Gears: ???
Re: TPI ram air.
I found this on hawksthirdgenparts.com.
http://www.hawksthirdgenparts.com/ca...mairboxes.aspx
Old Dec 16, 2008 | 08:20 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Re: TPI ram air.
Here's mine:
https://www.thirdgen.org/forums/auto...-air-pics.html
Old Dec 16, 2008 | 09:33 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: TPI ram air.
nice fiberglass box, id take one over the stainless IMO but i cant wait to see when your all done
Old Dec 17, 2008 | 12:56 PM
JMR's Avatar
JMR
Re: TPI ram air.
Racing geek, i have not installed one but 1bad91Z has, take a look at his link; moving along he might answer you question more accurately.
LT1Formula
20
Nov 14, 2015 12:02 AM
gixxer92
Sep 1, 2015 04:32 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
