New motor is flat tappet, has no bosses, HELP
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
ok so i got my block all cleaned up and finally pulled the intake, i havean LT1 cam and valvetrain in the mail coming to my house and i noticed that my bock, has no bosses for the webbing to hold the lifters.
birdto jag suggested we couldfab up a mountfor the webbing, anyone have any ideas???? he said we could weld 3 nuts onto a piece of sheetmetal and secure it that way but i thought you couldnt weld cast iron??
in a bind i need some help here
TIA
TIA
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: New motor is flat tappet, has no bosses, HELP
You bought an LT1 cam and valvetrain without knowing you have a flat tappet block? errr..... Learn from your mistakes eh?
No, cast iron is very difficult to weld to. However it's very easy to braze to. Either way, what you are asking to do is a very bad idea.
Do a search on this topic, L24 lifters is another keyword on this. Trying to shoehorn a roller cam in a flat tappet block requires some modifications that can seriously endanger your motor.
I'd just buy a flat tappet cam and go from there. Quick and dirty.
You can weld cast iron. Most people will tell you that it cannot be done but it can. If done properly.
You have to have the right rod if arc, not sure if you can mig, tig, or gas though. It's also a very expensive rod.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Just use aftermarket roller lifters that don't need the boss.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Even with retrofit rollers you have to figure out how to get a cam button to fit in the smaller bolt circle of the factory roller cam's sprocket.
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
i run a retro roller, the button isnt the hard part, its setting the clearance between the button and timing cover. i used a cast aluminum cover and ground it down, then put some putty on it, put it in place and measured the thikness of the putty where the button rests.
Engine: 383 Carb
Transmission: 4L60
With a factory roller cam, or with a retro-roller cam?
ahhhh, i see what your saying. yea n/m what i said, i have a aftermarket roller.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
yeah, bought the motor, threw it on the stand, been wokring 40 hrs a week/ going to school 9 hrs a day mon-thurs, didnt exactly have the time to tear into the motor, i bought the motor and lt1 setup because i was told that the bosses would already be there by another member. Crappy suprise lol
im thinking of just taking it down to 5 star engine in phoenix and trading out the motor as a core for a fully machined and rebuilt roller 350, unfortunately ill need another $800 but ill have to see how things go
Car: 1991 Firebird
Engine: 383 stroker
I also didn't see it mention, but even if you did get the 3 center bosses welded/brazed up and the cam button figured out, IIRC the block isn't machined flat enough for the 8 little plates that prevent your lifters from rotating in the lifter bore.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
we got the issue solved, i pulled the heads and found its a 305.... BS lol
birdtojag is hooking me up with a 4 bolt main roller 350 for close to free since thiswasnt the one i was looking for
Thank god for board connections eh?
Car: 1989 Camaro RS
Engine: 496 BBC
Transmission: T-56 6 speed
Axle/Gears: 4.11 posi
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
kinda, probly gonna rebuild it for fun lol sell it for a good price lol enough to cover costs atleast
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
You could also use the Cloyes Gear 9-221 from Summit. It is a nice cover, easy asjustment...
gixxer92
Sep 1, 2015 04:32 PM
