Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
custom crossmember
Old Feb 21, 2009 | 10:22 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
custom crossmember
anyone here yet has made a cross memember to run duals through? to get the exhaust to tuck up any higher. i know someone you could fabricate me one but it help that much. the problem is my car is lowered, and i still havent installed my dougs lt's.
Old Feb 21, 2009 | 01:14 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: custom crossmember
I'm sure there are more, but check out this thread:
https://www.thirdgen.org/forums/body...-phase-30.html
Start on page 30 for the exhaust/crossmember fab. Or start on page 1 if you have a few hours to kill. He's doing a hell of a job.
Old Feb 21, 2009 | 08:03 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
unfortunatelly i cant do it that way because i have an auto.
Old Feb 21, 2009 | 11:31 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I'm not sure how else you could do it. If you could post a pic or two of the underside of the car, that would help a lot.
Old Feb 23, 2009 | 12:26 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
ive found a way around this with my auto. but u cant do anything with the crossmember. there just isnt enough room around the trans for this in the farthest end by the crossmember.
look at iroc a 86 berli... his thread a few down "comp eng subframes" we've talked about his and he went the same way i did. for maximum ground clearance u have to notch the stock subframes and run it to the outside of the trans. pics are in the thread. but dont knotch your stock subframes unless u have installed good SFC that attach farther ahead from the point your knotching. my exhaust tucks up so nice it, it actually sits higher than my trans pan. and im running an xpipe and true dual 3" exhaust with hedman LTs.
Old Jan 15, 2011 | 02:23 PM
scottwrightF1's Avatar
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
Hi, I just wanted to post here and I know is a year old site.
Where is iroc a 86 berli? I could not find it.
Also does anyone here and or where I can find a custom make dual exhaust crossmember for my TPI with the D&D T56 trans that can attach or bolt the TA on the crossmember.
I know Hawks sells a dual crossmember, but it does not have a TA to bolt on it.
Let me know thanks.
Old Jan 15, 2011 | 03:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Let me know thanks.
doesn't exist, you have to make or modify one yourself
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
kammi10
Nov 9, 2015 08:28 PM
tmork454
Sep 29, 2015 06:33 PM
